regarding the problem with swath2grid, anything we can help
with? what's the problem you are stuck on? maybe someone here
has a bright idea to get past it.
Attached the result of a run, here some excerpt of the log file:
Processing LST ...
output lines/samples: 31819 2374
output pixel size: 0.0100
output data type: same as input
output upper left corner: lat 172.35803100 long -79.58354300
output lower right corner: lat -145.82196900 long -55.85354300
input lines/samples: 2030 1354
input resolution: 1 km
%% complete: 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%
