[I took liberty to cc grass-dev]
Michael,
2008/2/17, Michael Barton <michael.barton@asu.edu>:
>> When I included --with-wxwidgets, I got the following config error
>> checking for wx-config... /usr/bin/wx-config
>> checking wxWidgets version... 2.5.3
>> configure: error: *** wxWidgets 2.8.1 or later is required.
>> I check and it turns out I had a wx-config hidden away in
>> /usr/bin/wx-config. But it is old. No binaries since 2.5.3 (quite
>> awhile
>> back) have installed this. I looked at it and it is just a link to
>> a file
>> called mac-unicode-debug-2.5. This file seems to be a version of
>> wx-config.in created for Debian.
>> Somehow, we need to get this working on non-Debian systems. Not
>> for 6.3.0,
>> but definitely for later versions.
Martin:
> I am not sure if I am getting the point, you can define alternative
> location of wx-config. So find your wx-config for 2.8 and run
> --with-wxwidgets=path/to/your/wx-configThe problem is that the Mac doesn't have a wx-config. This file seems
to be Debian specific, or at least Linux specific.
no, wx-config is not at least Debian or GNU/Linux specific in general.
However I downloaded wxWidgets source code for Windows/Mac/All and I
found template for wx-config so I would expect you have wx-config on
your system too.
/home/martin/smetiste/wxMac-2.8.7/wx-config.in
/home/martin/smetiste/wxMac-2.8.7/wx-config-inplace.in
/home/martin/smetiste/wxMSW-2.8.7/wx-config.in
/home/martin/smetiste/wxMSW-2.8.7/wx-config-inplace.in
/home/martin/smetiste/wxWidgets-2.8.7/wx-config.in
/home/martin/smetiste/wxWidgets-2.8.7/wx-config-inplace.in
have a file or files that are functionally similar named
build_options.py and config.py in /Library/Frameworks/
Python.frameworks/Versions/current/lib/python2.5/site-packages/wx-2.8-
mac-unicode/wx/build/
Note that wx-config is part of wxWidgets not wxPython.
I'm attaching them here to see if they are functionally equivalent or
not. Note that the path I gave is specific to a Python 2.5 unicode
installation with wxPython 2.8.If looking for wx-config is simply to ascertain that wxPython does
indeed exist and checking its version, this should be doable in more
generic ways (e.g., I have a __version__.py file for wx that has this
information). If we need to access the information in wx-config, then
that too should be doable in a more generic, non-hard coded way. I
realize that it's not much help to just say something doesn't work
and not be able to suggest what does work.Maybe Glynn can help with this. It's still not clear to me what
specifically is needed to to compile vdigit. I did get the few extra
headers from the wxPython source. Maybe all I need is a path to
these. Or maybe it needs more. I can try to see if there are
equivalents already on my system if I know what I'm looking for.
William Kyngesbury may be able to help with this too, as he is more
familiar with configuration issues on a Mac than I am. Getting this
to work generically across Linux and Mac will be a big help to making
it work on Windows too. Windows may have a wx-config, but it's
probably not in /usr/bin.This will be something to work on for the next GRASS version.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
