[GRASS-dev] Re: [tlaronde: ticket #542: vector for GRASS 7]
Thierry:
[The exception for CERL GRASS siblings is i.ortho.photo and the like:
send everything to /dev/null and code from scratch. It's a nightmare...]
FWIW the curses like interface has been dropped for grass 7, so the only
bits of i.ortho.photo that remain are the libs. The idea is to keep the
algorithms but rewrite the rest in a platform independent way. this needs
a volunteer interested in photogrammetry (& has for years).
I have better wording in french, but not polyline.
what is it?
In KerGIS, I have added a flag to encode the _function_ linking the
vertices
ie f(x) ?
I think the "problem" is the point of view. When keeping Sites
(singularities) apart, you see more that they are, too, a connected
network of control points to describe a surface.
Not necessarily, they may be historic locations of churches or sampling
stations, or any x,y,z[,t[,n]] singularity (not limited by imagination)
for that matter. Not just spot samples of some continuous surface.
There was a lot that could be done with the ASCII listing of sites
(there could have been a binary version for symetry to speed things)
and with Unix powertools that is difficult to achieve dragging topology
and so on.
that was a big strength for grass 5, but perhaps limited in its database
connections.
Triangulation, Delaunay are a critical part of what should be here in
a GIS (GPL GRASS has things as far as I know; KerGIS not for
the moment).
modern grass has those things, but they need some finishing touches AFAIU.
see past Google Summer of Code projects.
if you wanted to be a hero :slight_smile: you could work on a BSD version of this:
  http://www.cs.cmu.edu/~quake/triangle.html
(very well implemented but non-free for commercial use*, so sadly mostly
unusable..)
[*] I think that's fair enough if the author wants it, except for the
NSF (public) funding of it.
Hamish
Hello,
thanks for the very interesting discussion.
My two cents regarding the delaunay triangulation:
the moment).
unusable..)
I have implemented a connection layer between GRASS and VTK
(www.vtk.org). Therefor all of the
VTK vector and image processing algorithms can process natively GRASS datasets.
And so the very good delaunay triangulation algorithms for 2d and 3d data:
http://www.vtk.org/doc/release/5.4/html/a00404.html
http://www.vtk.org/doc/release/5.4/html/a00405.html
No need to re-implement the wheel. :wink:
Example:
The delaunay triangulation grass-vtk python module:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Examples/v.delaunay2d.py
Computation time is quite equal to v.delaunay. But it ships better
documentation and several
options to optimize the output.
You can also convert raster maps into vector TIN's:
Here an example how to convert an elevation raster map into a TIN
using a VTK algorithm:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Examples/r.to.tin.py
* Results:
http://code.google.com/p/vtk-grass-bridge/wiki/rToTinResults
I have tested this algorithm with large datasets with more than 64
million cells creating
a TIN with about 3 million triangles. Memory usage is about 1.5 Gig.
Computation time ~20min
on Intel core2 with 2.1 Ghz.
VTK is licensed under a BSD license. Therefor you can implement
commercial algorithms in VTK
and use it in GRASS via the vtk-grass connection layer.
Best regards
Soeren
