[GRASS-dev] Re: vector works in X0 monitor but not in gis.m (Daniel Victoria)
I’ve committed the fix below suggested by Glynn. I tested it on the new NC demo data set and it causes no problems.
Of course, the old regexp statement worked too in my tests. Since I’m so abysmal at regexp, I just have to go with this, like I did with the old statement (someone else suggested it to fix an earlier problem with latlon regions).
Could someone please test this since I’m not completely clear what breaks the old algorithm that works with this one? Hopefully this will work with all projections this time.
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
On Dec 27, 2007, at 6:38 AM, grass-user-request@lists.osgeo.org wrote:
Probably related to this in mapcanvas.tcl:
Finally put this into wind file format to use with GRASS_REGION
regexp -nocase {^.* ((.*))} $parts(projection) trash end
set parts(projection) [string trim $parts(projection) $end]
The “*” operator will try to match as much as possble, so matching the
string “99 (Polyconic (American))” against the regexp"^.* ((.*))"
will result in the “." matching ""99 (Polyconic " and the "((.))”
matching “(American))”, so “end” will be set to “American)”
Also, using “string trim” here is bogus; it discards any leading or
trailing section consisting of characters in the specified string,
which may be more than just the string itself (if $end contains the
digit 9, it will strip the projection code).
It should probably just match the portion that it wants, e.g.:
regexp -nocase {^([0-9]+)} $parts(projection) trash parts(projection)
rather than trying to match and discard the portion that it doesn’t
want.
Glad to hear it. Thanks to Glynn for the suggested fix.
Michael
____________________
Phone: 480-965-6262
Fax: 480-965-7671
On Dec 31, 2007, at 9:47 AM, Daniel Victoria wrote:
Michael et al,
I'm happy to inform that I just compiled Grass from the latest svn and
the problem is gone. Map canvas works with both Polyconic American
projection and lat Long projection...
Cheers and happy new year!
Daniel
On Dec 27, 2007 7:07 PM, Daniel Victoria <daniel.victoria@gmail.com> wrote:
Thanks! I will gladly test the fix as soon as my r.watershed process
finishes. It's been running for 1 day and will probably take 2 more to
end... my laptop is almost melting...
Thanks again
Daniel
On Dec 27, 2007 6:47 PM, Michael Barton <michael.barton@asu.edu> wrote:
I've committed the fix below suggested by Glynn. I tested it on the new NC
Of course, the old regexp statement worked too in my tests. Since I'm so
regions).
Could someone please test this since I'm not completely clear what breaks
Michael
Phone: 480-965-6262
Fax: 480-965-7671
                # Finally put this into wind file format to use with
GRASS_REGION
                regexp -nocase {^.* (\(.*\))} $parts(projection) trash end
The "*" operator will try to match as much as possble, so matching the
string "99 (Polyconic (American))" against the regexp"^.* (\(.*\))"
will result in the ".*" matching ""99 (Polyconic " and the "(\(.*\))"
matching "(American))", so "end" will be set to "American)"
Also, using "string trim" here is bogus; it discards any leading or
parts(projection)
rather than trying to match and discard the portion that it doesn't
want.
grass-user mailing list
grass-user@lists.osgeo.org
grass-user Info Page
