hi Michael,
2007/2/1, Michael Barton <michael.barton@asu.edu>:
Jachym,
I did a quick glance and it looks like it will make working with display
layers much easier. Options panels can use these classes to define how
layers should be displayed.Somewhere we'll need to wrap this code into the integrated application. This
module is called render.py in my version--the one that I proposed renaming.
Maybe disputil.py would make more sense in the long run. I'm not sure yet
how much we should split up different functions into distinct smaller
modules and how much they should be expressed as classes in included in
larger modules.As we go along, we should keep trying to refactor like you've done here, and
produce clean code that will be easier to maintain in the future. I've
become acutely aware of this after untangling a lot of ancient TclTk
spaghetti code (some of it not so ancient and mine).Cheers
Michael
If you don't mind, I would start over the weekend or on Monday to
rewrite mapdispl.py, so it uses new mapimg.py (maybe it should be
renamed to maprender.py?).
Jachym
On 2/1/07 1:45 AM, "Jáchym Èepický" <jachym.cepicky@centrum.cz> wrote:
> hi Michael, it is good, that you are back!
>> Jachym,
>> I'm actually working with wx.Python again. Thank goodness it is starting to
>> come back to me after a 5 month hiatus. I decided to just focus on the
>> mundane tasks of the layer manager. This is good practice for me and pretty
>> straightforward in many respects, though sufficiently challenging (ie.,
>> difficult) that progress remains slow--for me at least. And I've only got
>> bits and pieces of time to devote to this at the moment.
>> What I've got now is a wx.Choicebook with a page for each display opened.
>> On that page is a wx.Notebook with a layer tree (at least theoretically
>> since I'm still trying to make it work) notebook page and a command console
>> notebook page. Each layer (i.e., node in the tree) will need a way to
>> indicate the name of the map in the layer, some indication (e.g., an icon)
>> of whether it is raster or vector (or something else), a way to make the
>> layer active/inactive, and some way to call up a panel to set the display
>> options for the layer. It looks like wx.CustomTreeCtrl will work quite well
>> for this. Once I get that far, I'll put it up on the cvs so that anyone can
>> play with it. If you'd like to see where I'm at any time, just let me know
>> and I'll send you some files.
>> One other thing is that the render.py module has become a handy place to
>> stash a few methods to track open displays, related variables, and the like
>> so that they don't instantiate new displays or control panels when
>> called--along with other display rendering functions. If it continues to
>> serve in this way, do you think we should rename it to something like
>> mapfunct.py or multifunct.py???
>> Just wanted to bring you up to date. Hope your trip is going well.
>> Cheers
>> Michael
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
> I started to define new set of classes, which should be easy to use
> and more logical orderd.
> Please look at the
> https://grasssvn.itc.it/grasssvn/grassaddons/trunk/grassaddons/gui/#_trunk_gra
> ssaddons_gui_
> you can test it with
> python mapimg.py
> and see the documentation with
> pydoc ./mapimg.py
> How to work with it, look at the end of mapimg.py
> Idea is, that each Map has defined set of layers (rasters, vectors,
> graphs, WMS, WCS, ...). This set of layers should be taken over by
> each Display.
> Let me know, if you like it
> I moved the work to grasssvn-addons repository, because this are all
> fresh ideas and the code is not mature yet. Ones we have basic working
> GUI, we shoul reorganize gui/wxpython directory. subversion anables us
> to rename the files and so on.
> I hope, you like it
> Jachym
> P.S. I Sent this e-mail in a copy to Martin Landa - second GUI developer.__________________________________________
Arizona State Universityphone: 480-965-6213
fax: 480-965-7671
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
