Hi!
Sorry I was not active for a long. But from now I will be giving my whole to contribute.
What can I do? I have already written some tests for modules and I can write more.
And if there is more stuff I can do please let me know.
Thank you
Sunveer
On Sat, 21 Jul 2018 at 17:52, Sunveer Singh <singhsunveer54@gmail.com> wrote:
Hi!
Hi Sunveer,
sorry for the delay in the answer, but this summer is really busy
yes you can write more test or improve translation of your mother
language [0] or look to some simple issue [1]
Thank you
Sunveer
[0] https://www.transifex.com/grass-gis/grass7/dashboard/
[1] https://trac.osgeo.org/grass/report/1
ciao
Luca
www.lucadelu.org
How was the GSoC this year? Hope you guys enjoyed mentoring new students!
I would like to contribute more tests, On which modules should I write test?
ยทยทยท
Thank You
Sunveer
https://sunveersingh.github.io/
On Thu, 23 Aug 2018 at 06:35, Sunveer Singh <singhsunveer54@gmail.com> wrote:
GSoC was hard but pleasant time
there are a lot of them... but some are really difficult, I suggest
you to look at the manual a choose someone that seems simple to you
r.buffer
r.buffer.lowmem
r.buildvrt
r.carve
r.category
r.circle
r.clump
r.coin
r.colors.out
r.composite
r.compress
r.contour
r.covar
r.cross
r.describe
r.distance
r.example
r.external
r.external.out
r.fill.dir
r.flow
r.his
r.in.aster
r.in.bin
r.in.gridatb
r.in.mat
r.in.srtm
r.in.wms
r.in.wms
r.in.xyz
r.kappa
r.lake
r.latlong
r.li
r.li.cwed
r.li.daemon
r.li.dominance
r.li.edgedensity
r.li.mpa
r.li.mps
r.li.padcv
r.li.padrange
r.li.padsd
r.li.patchdensity
r.li.patchnum
r.li.pielou
r.li.renyi
r.li.richness
r.li.shannon
r.li.shape
r.li.simpson
r.mfilter
r.neighbors
r.null
r.out.ascii
r.out.bin
r.out.gdal
r.out.gridatb
r.out.mat
r.out.mpeg
r.out.pov
r.out.ppm
r.out.ppm3
r.out.vrml
r.out.vtk
r.param.scale
r.plus.example
r.proj
r.quant
r.quantile
r.random
r.random.surface
r.reclass.area
r.region
r.regression.line
r.regression.multi
r.relief
r.resamp.bspline
r.resamp.filter
r.resamp.interp
r.resamp.rst
r.resamp.stats
r.resample
r.rescale
r.rescale.eq
r.ros
r.sim.sediment
r.sim.water
r.solute.transport
r.spread
r.spreadpath
r.statistics
r.stats.quantile
r.stats.zonal
r.stream.extract
r.sunhours
r.sunmask
r.support
r.support.stats
r.surf.area
r.surf.contour
r.surf.fractal
r.surf.gauss
r.surf.idw
r.surf.random
r.terraflow
r.thin
r.tile
r.to.rast3elev
r.topidx
r.topmodel
r.transect
r.uslek
r.usler
r.volume
r.walk
r.water.outlet
r.watershed
r.what
r.what.color
r3.cross.rast
r3.gwflow
r3.in.ascii
r3.in.lidar
r3.in.v5d
r3.in.xyz
r3.info
r3.mask
r3.mkdspf
r3.out.ascii
r3.out.bin
r3.out.v5d
r3.out.vtk
r3.retile
r3.showdspf
r3.stats
r3.support
t.create
t.list
t.rast.colors
t.rast.list
t.rast.mapcalc
t.rast.out.vtk
t.rast3d.mapcalc
t.register
t.remove
t.rename
t.select
t.topology
t.vect.db.select
t.vect.export
t.vect.what.strds
v.buffer
v.build
v.build.all
v.build.polylines
v.class
v.cluster
v.colors
v.colors.out
v.db.connect
v.decimate
v.delaunay
v.drape
v.example
v.external
v.external.out
v.extrude
v.generalize
v.hull
v.import
v.in.db
v.in.dwg
v.in.dxf
v.in.e00
v.in.geonames
v.in.mapgen
v.in.ogr
v.in.region
v.in.wfs
v.kcv
v.kernel
v.label
v.label.sa
v.lidar.correction
v.lidar.edgedetection
v.lidar.growing
v.lrs
v.lrs.create
v.lrs.label
v.lrs.segment
v.lrs.where
v.mkgrid
v.neighbors
v.net.alloc
v.net.allpairs
v.net.bridge
v.net.centrality
v.net.components
v.net.connectivity
v.net.distance
v.net.flow
v.net.iso
v.net.path
v.net.salesman
v.net.spanningtree
v.net.steiner
v.net.timetable
v.net.visibility
v.normal
v.out.ascii
v.out.dxf
v.out.ogr
v.out.postgis
v.out.pov
v.out.svg
v.out.vtk
v.outlier
v.overlay
v.parallel
v.patch
v.perturb
v.proj
v.qcount
v.random
v.reclass
v.rectify
v.sample
v.segment
v.split
v.support
v.surf.idw
v.to.db
v.to.points
v.to.rast
v.to.rast3
v.transform
v.type
v.vol.rst
v.voronoi
v.what.rast
Thank You
Sunveer
ciao
Luca
www.lucadelu.org
