A very interesting and frustrating problem has just presented itself to me. The region settings seem to "break" after using the new zoom tools from the map display. i get the following error message in the Output window:
region for current mapset is invalid
line 15: <depths: 0>
run "g.region"
This message displays after zooming a few times, or after attempting to do anything at all with "g.region" (including just printing region settings). Also, all the new zoom tools in the map display seem to do nothing after this message, and I cannot display any of the maps in my mapset. I have looked at the WIND file for the afflicted mapsets, and they seem perfectly normal. For example, the above error message is associated with the following WIND file:
proj: 1
zone: 36
north: 3742844.70455
south: 3309044.70455
east: 944264.754065
west: 560076.932184
cols: 12806
rows: 14460
e-w resol: 30.0006108
n-s resol: 30
top: 1
bottom: 0
cols3: 12806
rows3: 14460
depths: 1
e-w resol3: 30.0006108
n-s resol3: 30
t-b resol: 1
Making a new mapset allows me to run "g.region" without any problems until I use the new zooming tools, and then the same problem occurs. Restarting GRASS initially allows for the maps to be displayed again, but after zooming a bit, or trying to run "g.region" again, the region eventually "breaks" again. What I specifically do not understand is why the error tells me to run "g.region" when doing so does nothing, and seems to even cause the error in the first place. Does anybody have any idea what the issue is here? I am using GRASS 6.3, compiled from the CVS source yesterday (08/15)... Any help would be greatly appreciated.
Isaac
Hi Isaac,
a solution for this (known) problem was proposed by Martin Landa a
few days ago:
http://grass.itc.it/pipermail/grass-dev/2006-August/025040.html
Since he should have CVS write access now, I hope that
he'll submit the patch asap.
On Tue, Aug 15, 2006 at 06:07:09PM +0000, Isaac Ullah wrote:
the Output window:
run "g.region"
proj: 1
zone: 36
east: 944264.754065
west: 560076.932184
cols: 12806
rows: 14460
n-s resol: 30
top: 1
bottom: 0
cols3: 12806
rows3: 14460
depths: 1
n-s resol3: 30
t-b resol: 1
Isaac
grass-dev mailing list
grass-dev@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Greetings all,
I am attempting to build GRASS 6.1.0 here, and I am getting undefined errors for EXIT_FAILURE and EXIT_SUCCESS.
After greping around a bit, I cannot find those constants defined anywhere. Where might they supposed to be defined?
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 877.240.1364
They are defined in the ANSI C standard and reside in stdlib.h.
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
I can confirm this. There seems no way to satify g.region. We've set the
WIND file manually and still get the same error.
We did a make distclean and recompiled today (15 August) and still have the
same results. This is on an FC4 32bit system.
I tried the identical actions on my Mac, using 6.1.0 binaries compiled 12
August and had no trouble at all.
Did something change with g.region? Could this be due to the parser changes
that Markus mentioned earlier today?
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 15 Aug 2006 18:07:09 +0000
To: <grass-dev@grass.itc.it>
Subject: [GRASS-dev] Region problems in grass 6.3 (maybe also 6.1)...
the Output window:
run "g.region"
proj: 1
zone: 36
east: 944264.754065
west: 560076.932184
cols: 12806
rows: 14460
n-s resol: 30
top: 1
bottom: 0
cols3: 12806
rows3: 14460
depths: 1
n-s resol3: 30
t-b resol: 1
Isaac
Brad Douglas wrote on 08/16/2006 06:31 AM:
Jeshua,
where did that exactly happen (module, library)?
Michael,
this bug I know for > 1 year. I hope that Martin submits his patch.
Michael Barton wrote on 08/16/2006 08:13 AM:
Michael
phone: 480-965-6213
fax: 480-965-7671
www: Sign in ・ Cloudflare Access
the Output window:
run "g.region"
proj: 1
zone: 36
east: 944264.754065
west: 560076.932184
cols: 12806
rows: 14460
n-s resol: 30
top: 1
bottom: 0
cols3: 12806
rows3: 14460
depths: 1
n-s resol3: 30
t-b resol: 1
Isaac
Hello Markus,
With the modules:
v.out.dxf
r.to.vect
Sure enough, including stdlib.h did the trick (thanks Brad!)...
Let me know if I may be of any assistance.
phone: 877.240.1364
So, which modules are generating errors? Presumably, they aren't
including stdlib.h.
I'm glad it's known and has a fix in the works. But why is it just showing
up now and doesn't affect 6.1?
Michael
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 16 Aug 2006 10:10:48 +0200
To: Michael Barton <michael.barton@asu.edu>
Cc: <grass-dev@grass.itc.it>, Martin Landa <landa.martin@gmail.com>
Subject: Re: [GRASS-dev] Region problems in grass 6.3 (maybe also 6.1)...
Michael,
Michael
phone: 480-965-6213
fax: 480-965-7671
the Output window:
run "g.region"
proj: 1
zone: 36
east: 944264.754065
west: 560076.932184
cols: 12806
rows: 14460
n-s resol: 30
top: 1
bottom: 0
cols3: 12806
rows3: 14460
depths: 1
n-s resol3: 30
t-b resol: 1
Isaac
I will submit this patch as soon as I have CVS write access...
Best, Martin
2006/8/16, Markus Neteler <neteler@itc.it>:
Michael,
> Michael
> phone: 480-965-6213
> fax: 480-965-7671
>> From: Isaac Ullah <isaac.ullah@asu.edu>
>> Hi all,
>> the Output window:
>> run "g.region"
>> proj: 1
>> zone: 36
>> east: 944264.754065
>> west: 560076.932184
>> cols: 12806
>> rows: 14460
>> n-s resol: 30
>> top: 1
>> bottom: 0
>> cols3: 12806
>> rows3: 14460
>> depths: 1
>> n-s resol3: 30
>> t-b resol: 1
>> Cheers,
>> Isaac
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
I see reports go back to the first week of July, so I believe both are
affected.
Michael
phone: 480-965-6213
fax: 480-965-7671
> From: Markus Neteler <neteler@itc.it>
> Michael,
> Markus
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Hi all,
>>> the Output window:
>>> run "g.region"
>>> proj: 1
>>> zone: 36
>>> east: 944264.754065
>>> west: 560076.932184
>>> cols: 12806
>>> rows: 14460
>>> n-s resol: 30
>>> top: 1
>>> bottom: 0
>>> cols3: 12806
>>> rows3: 14460
>>> depths: 1
>>> n-s resol3: 30
>>> t-b resol: 1
>>> Cheers,
>>> Isaac
