[GRASS-dev] [release] GRASS 7.2.1RC2
based on roadmap published in ML [1] we could go out with RC2. There are no
blockers registered [2], so it is seems that we can slowly start
preparing RC2. Any objections?
Ma
[1] https://lists.osgeo.org/pipermail/grass-dev/2017-February/084328.html
[2] https://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&priority=blocker&priority=critical&milestone=7.2.1&milestone=7.2.0&group=type&order=priority
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Le 17 avril 2017 20:22:35 GMT+02:00, Martin Landa <landa.martin@gmail.com> a écrit :
are no
preparing RC2.
+1
Moritz
Ma
[1]
[2]
Martin Landa
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Apr 18, 2017 3:20 PM, “Moritz Lennert” <mlennert@club.worldonline.be> wrote:
are no
preparing RC2.
+1
While generally yes, we still lack the po files update from transifex…
[1]
[2]
On 20 April 2017 at 19:12, Markus Neteler <neteler@osgeo.org> wrote:
While generally yes, we still lack the po files update from transifex...
The problem right now is the Portuguese translations files, mods an
libs po file return a lot of "invalid multibyte sequence"
You can try your self following the wiki instructions [0] (they were
there also during your visit :frowning: )
[0] https://grasswiki.osgeo.org/wiki/GRASS_messages_translation#Get_the_translated_po_files
ciao
Luca
www.lucadelu.org
There is another problem, all the fuzzy strings had lost during the
import, you can read more here
https://groups.google.com/forum/#!topic/transifex-updates/zICBvn-823o
So probably before merge we should decide what to do, I suggest a
translation sprint...
ciao
Luca
www.lucadelu.org
2017-04-22 9:34 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
is it blocker for 7.2.1 release? In any case RC2 can be released
regardless of this issue, right? Ma
Martin Landa
Fixed. The file simply needed to be converted to UTF-8 from ISO-8859-1
using iconv + editing of the header:
for i in `ls grass*_pt.po ` ; do iconv -f ISO-8859-1 -t UTF-8 $i >
dd.tmp ; \mv dd.tmp $i ; done
... then edit all three files for the header update of encoding.
No more "invalid multibyte sequence" errors.
Perhaps we should convert all .po files to UTF-8? This is not yet the case.
Additional observations:
- the transifex_merge.sh deletes all headers along with the translation authors
- it empties all "fuzzy" state messages.
Due to that I didn't merge yet the updated translations. I try to
understand where the header replacement with the generic gettext
header happens.
Done, both in trunk and relbranch72.
Fixed: I have implemented extra code in grass-addons/tools/transifex_merge.sh
This discussion is from 2011:
perhaps it became this:
https://docs.transifex.com/setup/translation-memory
However, I'll prepare RC2 now.
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
On Mon, Apr 17, 2017 at 8:22 PM, Martin Landa <landa.martin@gmail.com> wrote:
GRASS GIS 7.2.1RC2 is out:
https://grass.osgeo.org/grass72/source/
Binary packages to be prepared... hoping that this is the last RC,
let's also draft the release notes:
https://trac.osgeo.org/grass/wiki/Release/7.2.1-News
Should the demolocation include a .bash_history & .bashrc?
It seems to be leaking your (neteler) environment.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
Fedora + EPEL7 binary RPMs:
https://copr.fedorainfracloud.org/coprs/neteler/grass72
EPEL 6 binary RPMs:
https://copr.fedorainfracloud.org/coprs/neteler/grass72_epel6
cheers,
Markus Neteler, PhD
On Sat, Apr 22, 2017 at 9:59 PM, Sebastiaan Couwenberg
Good catch, removed from tarball.
2017-04-22 19:49 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
winGRASS packages available for testing:
* native [1]
* OSGeo4W testing (exp) area
Ma
[1] https://grass.osgeo.org/grass72/binary/mswindows/native/
Martin Landa
2017-04-23 11:11 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
also Ubuntu packages (trusty, xenial, zesty) available for testing
from UbuntuGIS Expr PPA [1].
Ma
[1] https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-experimental/+packages?field.name_filter=grass&field.status_filter=published&field.series_filter=
Martin Landa
Please note that zesty is not an LTS release, and won't be supported by
UbuntuGIS. None of the other packages will be available for it.
Kind Regards,
Bas
2017-04-23 16:17 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
update: UbuntuGIS should maintain only packages for LTS Ubuntu
releases. So you will find in Expr/Unstable PPA GRASS packages only
for trusty and xenial. For other Ubuntu releases will be used our
GRASS Stable PPA repo [1]. I changed website accordingly [2]. Ma
[1] https://launchpad.net/~grass/+archive/ubuntu/grass-stable
[2] https://grass.osgeo.org/download/software/linux/
Martin Landa
