[GRASS-dev] [release planning] 7.4.1
Hi devs,
according to our roadmap [1] it is time to prepare 7.4.1RC1:
Time schedule:
Proposal of release: ~14 Mar
Soft freeze of release branch: ~23 Mar
RC1: ~23 Apr <<-- we are here
RC2: ~7 May
Final release: ~14 May
We have no blockers any more [2].
If there are no objections, I'll prepare RC1 in the next few days.
[1] https://trac.osgeo.org/grass/milestone/7.4.1
[2] https://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&milestone=7.4.1&milestone=7.4.0&group=type&order=priority
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
Markus Neteler wrote
Hi devs,
Time schedule:
RC2: ~7 May
+1
As daily winGRASS builds seems to be broken for some times now, it may be
needed to find a way to test the RCs.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
2018-04-25 23:16 GMT+02:00 Helmut Kudrnovsky <hellik@web.de>:
apparently something wrong with server again, what a pain. Will
investigate more. Thanks for pointer. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
2018-04-25 23:45 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
I pushed build manually, seems to work [1]. Will see if new builds
appear tomorrow.
Ma
[1] https://wingrass.fsv.cvut.cz/grass74/x86_64/
Martin Landa
If someone could have a look at #3546 (t.rast.what ), that would be splendid.
With introduction of the category flag (which is very useful) columns unfortunately get shifted in "col" output. So resulting CSV header has to be treated specially in later usage of the module output.
There is a fix in trunk, but it needs testing and maybe agreement / a second opinion regarding the proposed fix.
The provided fix keeps cat and x/y together using different identifiers.
Alternatively, only cat could be used (and coordinates could be dropped).
I would really like to get a fix into 7.4.1, as this module (and option) is used relatively frequently.
Once agreed on the most suitable fix, I can add that case to the test suit and update the manual as needed...
Stefan
https://trac.osgeo.org/grass/ticket/3546
-----Original Message-----
From: grass-dev <grass-dev-bounces@lists.osgeo.org> On Behalf Of Helmut Kudrnovsky
Sent: onsdag 25. april 2018 23.17
To: grass-dev@lists.osgeo.org
Subject: Re: [GRASS-dev] [release planning] 7.4.1
Hi devs,
Time schedule:
RC2: ~7 May
+1
As daily winGRASS builds seems to be broken for some times now, it may be needed to find a way to test the RCs.
best regards
Helmut
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
2018-04-25 20:26 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
since there is no blocker [1] I suggest to go ahead and prepare RC1 ASAP. Martin
[1] https://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&priority=blocker&priority=critical&milestone=7.4.1&milestone=7.4.0&group=type&order=priority
Martin Landa
On Fri, May 4, 2018 at 10:02 PM, Martin Landa <landa.martin@gmail.com> wrote:
Delayed with respect to our roadmap I have now tagged GRASS GIS 7.4.1 RC1:
* Source code: https://grass.osgeo.org/grass74/source/grass-7.4.1RC1.tar.gz
* SVN Source Code Checkout 7.4.1RC1:
    svn checkout
https://svn.osgeo.org/grass/grass/tags/release_20180504_grass_7_4_1RC1
* Draft release notes (please update!):
    https://trac.osgeo.org/grass/wiki/Release/7.4.1-News
Please test!
2018-05-04 23:14 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Please test!
WinGRASS packages available for testing. Both standalone [1] and
OSGeo4W (Expr/Testing area).
Ma
[1] https://grass.osgeo.org/grass74/binary/mswindows/native/
Martin Landa
If there are no objections, I’ll prepare RC1 in the next few days.
Please test!
FYI, I just backported a bugfix for v.out.ogr in r72694, avoiding duplicate fid’s which resulted in an incomplete export in some cases for some output formats, e.g. GPKG.
Markus M
2018-05-05 22:35 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
Please test!
experimental package for Ubuntu Xenial also available in UbuntuGIS
Expr [1]. Will prepare package also for Bionic (18.04LTS). I am
planning drop support for Trusty (OldOld LTS) - build packages only on
request.
Ma
[1] https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-experimental/+packages?field.name_filter=grass&field.status_filter=published&field.series_filter=
Martin Landa
Hi Markus,
2018-05-07 23:37 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
request.
it's two weeks from RC1, I would go ahead with RC2. Any objections? Martin
Martin Landa
Am 15.05.2018 11:46 schrieb Martin Landa:
Hi Markus,
request.
None from me.
Moritz
On Tue, May 15, 2018 at 11:46 AM, Martin Landa <landa.martin@gmail.com> wrote:
Hi Markus,
Yes, fine for me. I can tag it tomorrow night.
On Tue, May 15, 2018 at 11:46 AM, Martin Landa &lt;
landa.martin@
&gt; wrote:
Hi Markus,
Martin
what are the main fixes to go from RC1 to RC2?
tested RC1 on windows and debian, so far ok.
best regards
Helmut
landa.martin@
> wrote:
Hi Markus,
it’s two weeks from RC1, I would go ahead with RC2. Any objections?
Martin
An important fix is v.out.ogr r72694: avoid duplicate fid’s which can cause incomplete exports.
The recent changes to v.select in trunk are not really a bugfix, but considering that v.select is now about 10x faster in some cases, it might qualify for backporting to 7.4RC2. Any opinion?
Markus M
best regards
Helmut
If there are no objections, I would like to backport fixes in https://trac.osgeo.org/grass/ticket/3546
before RC2 (can do that immediately).
Tests would probably need updating though?!
Stefan
Sent: onsdag 16. mai 2018 00.44
landa.martin@
&gt; wrote:
Hi Markus,
Martin
best regards
Helmut
Am 16. Mai 2018 10:06:31 MESZ schrieb Markus Metz <markus.metz.giswork@gmail.com>:
> landa.martin@
> &gt; wrote:
>> Hi Markus,
objections?
>> Martin
An important fix is v.out.ogr r72694: avoid duplicate fid's which can
cause
incomplete exports.
might
I haven't had the possibility to test, yet, but the slow speed could be considered a bug, and so if you are confident that the changes do not provoke any unforeseen consequences, I would be happy to go for an exception to our usual rule and say, yes please ! But IIUC RC2 has already been tagged, or ?
Moritz
Markus M
best regards
Helmut
Sent from:
2018-05-16 10:29 GMT+02:00 Moritz Lennert <mlennert@club.worldonline.be>:
+1
Not yet [1]. Ma
[1] https://trac.osgeo.org/grass/browser#grass/tags
Martin Landa
On Wed, May 16, 2018 at 10:33 AM, Martin Landa <landa.martin@gmail.com> wrote:
I haven’t had the possibility to test, yet, but the slow speed could be considered a bug, and so if you are confident that the changes do not provoke any unforeseen
+1
I tested the new v.select in various scenarios: it is much faster using extreme input combinations, otherwise processing speed is similar. Results are in various tests identical.
Not yet [1]. Ma
OK, backported to 7.4 with r72715.
Markus M
Martin Landa
Hi devs,
are we ready for RC2 or do we still have urgent issues to be fixed?
thanks,
