[GRASS-dev] release planning and no volume display on Mac - Any info on where crash happens?
When I put in values between 15 and 20 I can see the horizontal outline of a rectangle but not the 3D shape of a box. No isosurfaces display. No crash either.
I un-commented line 684 and commented line 1009 in gvl_calc_c to see what happens to slices
/* gvl_align_data(pos, slice->data); */
A horizontal slice displays and I can manipulate it in the X and Y direction. But I cannot manipulate it in the Z direction. Also, a Z dimension slice shows up only as a line. Also, isosurfaces do not display. But there is no crash for either isosurfaces or slices when I comment out this line. On the face of it, a memory issue related to display in the Z dimension is causing a crash. Commenting out calls to gvl_align_data in gvl_calc_c stops the crash and stops display in the Z dimension. There is also something called gvl_calc2_c in this folder. Its code is very similar to gvl_calc_c
I'm guessing that Martin and Helena know the most about the relevant C code for lib/ogsf/*. Glynn may have some insight into this too. Anyone else is welcome to chime in.
FWIW, the last time gvl_calc_c was touched was by Glynn 4 years ago (glynn: Fix char/char* mismatch (merge from trunk, r32757)).
Volume display worked as recently as fall 2011 AFAIK.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jan 2, 2013, at 10:21 AM, Helena Mitasova <hmitaso@ncsu.edu> wrote:
On Jan 2, 2013, at 1:34 AM, Michael Barton wrote:
Testing with GRASS 6.4.3RC2
Rem-ing out line 684 in gvl_calc_c
/* gvl_align_data(dbuff[i].ndx_new, dbuff[i].new); */
prevents crashing. But I don't see an isosurface.
Helena,
I'm using your test data (jr_7408MR_2m_t70)
What is a good value to set for an isosurface to see anything?
anything between 15 to 20 should work.
You can move the volume a little bit above the surface to see the entire isosurface
Here is an example of settings that I have used (the name of the volume raster is slightly different
but it is the same data).
m.nviz.image elevation_map=JR_2008_ALL -a mode=fine resolution_fine=1 color=243:243:243 volume=JR_7408MR_2m volume_shading=gouraud volume_resolution=1 volume_position=0,0,20 isosurf_level=1:17.0 isosurf_color_map=JR_7408MR_2m isosurf_transp_value=0 position=0.11,0.07 height=243 perspective=13 twist=0 zexag=6.000000 focus=569,593,17 light_position=0.26,-0.30,0.61 light_brightness=94 light_ambient=55 light_color=255:255:255 output=nviz_output format=ppm size=798,545
This volume includes no-data because the original rasters were masked, I think it would be useful to start with a volume without no-data -
just use r3.null to replace no-data with 0.
Let me know if it would be useful for me to run same thing in MacOSX 10.6 (I still don't have 10.8 machine quite ready),
(see the slides 12 and 13 here for the isosurfaces at different levels, I have the isosurfaces colored by year - I don't think I gave you
that raster, so your isosurfaces should be just a single color).
http://skagit.meas.ncsu.edu/~helena/publwork/AGU2012lidar6.pptx
Helena
Slices still crash because they still call gvl_align_data. As before, though initially displaying a slice works fine. It only crashes when I try to change something about the slice and it wants to redraw.
Michael
C. Michael Barton
On Jan 1, 2013, at 1:24 PM, Anna Kratochvílová <kratochanna@gmail.com>
wrote:
Hi Michael,
On Tue, Jan 1, 2013 at 8:48 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Hi Anna,
On the slim chance that you are online today, can you tell me where gvl_align_data in gvl_calc.c reside in either the source code or compiled code? I have a bit of down time and thought I'd see what I could find out about the volume display breaking. I don't know C but can selectively rem out some things and see what happens.
It should be here
gvl_calc.c in grass/trunk/lib/ogsf – GRASS GIS
Also, you could try debugging with QtCreator [1] (as an user-friendly
interface to the debugger), it is quite easy, here [2] is some help
for setting up the project. I don't know what method you would like to
use but this is the easiest I know. I suppose it should work on Mac,
too.
Anna
[1] The Qt Project
[2] Using QtCreator for GRASS C development - GRASS-Wiki
Thanks
Michael
C. Michael Barton
On Dec 6, 2012, at 12:07 AM, Anna Kratochvílová <kratochanna@gmail.com> wrote:
Hi Michael,
On Wed, Dec 5, 2012 at 11:02 PM, Michael Barton <michael.barton@asu.edu> wrote:
Any suggestions yet on where the crash I documented in
#1736 (wxNVIZ volume display crashes Mac) – GRASS GIS actually happens in the code so that
I can take a look at it and see if there is something fixable for the Mac? I
posted what I hope is the relevant debug output to help identify this.
While we may need to think about wxPython 2.9, it seems best to first look
at what line is actually causing the crash and see if there is a fix or
workaround.
The crash occurs probably in gvl_align_data in gvl_calc.c. The error
message 'pointer being realloc'd was not allocated' is quite clear,
however it's not clear why it happens on Mac only. Maybe someone with
better knowledge of C could understand it more.
Anna
Michael
C. Michael Barton
Michael,
what you describe sounds as if you had only one depth layer so let us check first that the 3D region is right.
If the 3d region is set to the provided 3d raster given here
http://skagit.meas.ncsu.edu/~helena/grasswork/JR_7408MR_2m_t70.asci
http://skagit.meas.ncsu.edu/~helena/grasswork/JR_2008_ALL.asci (reference 2d raster)
it should look like this
GRASS 6.4.3svn (nc_spm_05):~ > g.region -p3
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
can you then try to run the following command (please adjust the names of the 2d and 3d rasters to your actual names)
m.nviz.image elevation_map=JR_2008_ALL@Baseline_JR -a mode=fine resolution_fine=6 color_map=JR_2008_ALL@Baseline_JR \
volume=JR_7408MR_2m_t70@Baseline_JR volume_shading=gouraud volume_resolution=1 volume_position=0,0,20 isosurf_level=1:18.0 isosurf_color_map=JR_7408MR_2m_t70@Baseline_JR isosurf_transparency_value=0 slice=1:x,1:z slice_position=0.000000,1.000000,0.520000,1.000000,0.000000,1.000000,0.250000,0.720000,0.080000,1.000000,0.000000,1.000000 slice_transparency=0,0 position=0.84,0.16 height=356 perspective=20 twist=0 zexag=5.000000 focus=569,593,28 \
light_position=0.68,0.68,0.80 light_brightness=80 light_ambient=20 light_color=255:255:255 \
output=jrvoltest format=tif size=798,545
it should generate an image with isosurfaces and a tilted crossection - it is not quite what I have on the screen, because
it apparently uses some default values instead of actual values (e.g. for toggle normal direction and crossection) but it should have some
isosurfaces. Let us know whether the command line works and we can go from there.
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
http://trac.osgeo.org/grass/browser/grass/trunk/lib/ogsf/gvl_calc.c#L685
too.
Anna
[1] http://qt-project.org/downloads
[2] http://grasswiki.osgeo.org/wiki/Using_QtCreator_for_GRASS_C_development#Debugging
Thanks
Michael
C. Michael Barton
Hi Michael,
http://trac.osgeo.org/grass/ticket/1736 actually happens in the code so that
workaround.
Anna
Michael
C. Michael Barton
Aha. You were right. The tbres and top bound was set to 1. Odd since I use set the region to match the 3d map.
So I'll try it again and with the command and report back.
Michael
C. Michael Barton
On Jan 2, 2013, at 10:45 PM, Helena Mitasova <hmitaso@ncsu.edu>
wrote:
Michael,
zone: 0
datum: nad83
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
too.
Anna
[1] The Qt Project
Thanks
Michael
C. Michael Barton
Hi Michael,
workaround.
Anna
Michael
C. Michael Barton
GREAT NEWS!
Commenting out both gvl_align_data lines (#684 and #1009) in gvl_calc_c makes this work. Both slices and isosurfaces display and do not crash. I don't know if there would be a problem with larger files or not. But this is finally functional again.
BUT the command you sent does NOT work. It gives a segmentation fault error:
m.nviz.image elevation_map=JR_2008_ALL_dem@test3d -a mode=fine resolution_fine=6 color_map=JR_2008_ALL_dem@test3d volume=jr_7408MR_2m_t70@test3d volume_shading=gouraud volume_resolution=1 volume_position=0,0,20 isosurf_level=1:18.0 isosurf_color_map=jr_7408MR_2m_t70@test3d isosurf_transparency_value=0 slice=1:x,1:z slice_position=0.000000,1.000000,0.520000,1.000000,0.000000,1.000000,0.250000,0.720000,0.080000,1.000000,0.000000,1.000000 slice_transparency=0,0 position=0.84,0.16 height=356 perspective=20 twist=0 zexag=5.000000 focus=569,593,28 light_position=0.68,0.68,0.80 light_brightness=80 light_ambient=20 light_color=255:255:255 output=jrvoltest format=tif size=798,545
Loading raster map <JR_2008_ALL_dem@test3d>...
100%
100%
Translating colors from raster map <JR_2008_ALL_dem@test3d>...
100%
Loading 3d raster map <jr_7408MR_2m_t70@test3d>...
Segmentation fault: 11
Also, somewhere there is a bug somewhere that is sending progress bar text to the screen for any nviz activity (GRASS_INFO_PERCENT: 0...)
So now we have some kind of workaround. I don't know if there are any other down sides to bypassing this memory reallocation, but this is a good start on fixing this finally. Thanks Anna and Helena.
Michael
C. Michael Barton
wrote:
Michael,
zone: 0
datum: nad83
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
too.
Anna
[1] The Qt Project
Thanks
Michael
C. Michael Barton
Hi Michael,
workaround.
Anna
Michael
C. Michael Barton
So I found a change that would make volumes visible again a week ago. Anyone have any thoughts about this? Do we need the function/procedure that sets the memory pointer for volume displays? Or can we simply get rid of it? Is it needed for Linux? Windows? Any thoughts about what happens without it?
Michael
C. Michael Barton
On Jan 2, 2013, at 11:22 PM, Michael Barton <michael.barton@asu.edu> wrote:
GREAT NEWS!
100%
100%
100%
Michael
C. Michael Barton
wrote:
Michael,
zone: 0
datum: nad83
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
too.
Anna
[1] The Qt Project
Thanks
Michael
C. Michael Barton
Hi Michael,
workaround.
Anna
Michael
C. Michael Barton
Hi Michael,
On Mon, Jan 7, 2013 at 7:57 AM, Michael Barton <Michael.Barton@asu.edu> wrote:
I can confirm that removing those two lines does no harm for me
(Linux). However it's clear that we cannot just leave them out without
understanding why they are there. Can anyone (for example Glynn) think
of a reason why this code is crashing on Mac and not on Linux (no idea
about Windows)?
And why removing of realloc helps?
Anna
Michael
C. Michael Barton
GREAT NEWS!
100%
100%
100%
Michael
C. Michael Barton
wrote:
Michael,
zone: 0
datum: nad83
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
too.
Anna
Thanks
Michael
C. Michael Barton
Hi Michael,
workaround.
Anna
Michael
C. Michael Barton
On Jan 11, 2013, at 2:48 PM, Anna Kratochvílová wrote:
Hi Michael,
about Windows)?
I just tested it on Windows 7 with WinGRASS6.4.3RC2 and I am happy to report that it works OK
- both isosurfaces and crossections.
However, in the same WinGRASS6.4.3.RC2 there is a problem with the path to cellheader in G3d_read_window,
so r3.info and g.region rast3d=myvoxel gives an error that the region is invalid.
Also, I finally got a laptop with MacOSX10.8 and I can confirm that in GRASS6.4.3RC2 binary
posted Michael isusrfaces crash wxGUI. I will try to compile myself but I expect the result
to be the same given that it crashed for William as well.
Helena
Anna
Michael
C. Michael Barton
GREAT NEWS!
100%
100%
100%
Michael
C. Michael Barton
wrote:
Michael,
zone: 0
datum: nad83
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
too.
Anna
Thanks
Michael
C. Michael Barton
Hi Michael,
workaround.
Anna
Michael
C. Michael Barton
Perhaps Windows and Linux--and earlier versions of OS X--ignore the code.
The header for gvl_calc.c says that the author is Tomas Paudits (February 2004). Does anyone know if he is still around to ask?
Michael
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
On Jan 11, 2013, at 1:18 PM, Helena Mitasova <hmitaso@ncsu.edu>
Hi Michael,
about Windows)?
Helena
Anna
Michael
C. Michael Barton
GREAT NEWS!
100%
100%
100%
Michael
C. Michael Barton
wrote:
Michael,
zone: 0
datum: nad83
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
too.
Anna
[1] The Qt Project
Thanks
Michael
C. Michael Barton
Hi Michael,
workaround.
Anna
Michael
C. Michael Barton
I have not commented out both gvl_align_data lines (#684 and #1009) in
gvl_calc.c, but fixed variable initialization in trunk r54866. Please
test.
Markus M
On Fri, Jan 11, 2013 at 10:33 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Michael
C. Michael Barton
USA
Hi Michael,
about Windows)?
Helena
Anna
Michael
C. Michael Barton
GREAT NEWS!
100%
100%
100%
Michael
C. Michael Barton
wrote:
Michael,
zone: 0
datum: nad83
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
too.
Anna
Thanks
Michael
C. Michael Barton
Hi Michael,
workaround.
Anna
Michael
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
I will try to test today if I can. Thanks.
Michael
C. Michael Barton
On Feb 3, 2013, at 5:16 AM, Markus Metz <markus.metz.giswork@gmail.com>
test.
Markus M
Michael
C. Michael Barton
USA
Hi Michael,
about Windows)?
Helena
Anna
Michael
C. Michael Barton
GREAT NEWS!
100%
100%
100%
Michael
C. Michael Barton
wrote:
Michael,
zone: 0
datum: nad83
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
too.
Anna
[1] The Qt Project
Thanks
Michael
C. Michael Barton
Hi Michael,
workaround.
Anna
Michael
C. Michael Barton
grass-dev Info Page
Markus and others,
I just tested this with GRASS trunk r54874 and it is still broken.
Removing all reference to lines gvl_align_data (and the function as well) works. AFAICT, this only is called for viewing volumes. Does removing this function break volume viewing for any other platform?
Michael
C. Michael Barton
test.
Markus M
Michael
C. Michael Barton
USA
Hi Michael,
about Windows)?
Helena
Anna
Michael
C. Michael Barton
GREAT NEWS!
100%
100%
100%
Michael
C. Michael Barton
wrote:
Michael,
zone: 0
datum: nad83
north: 250690
south: 249502
west: 912791
east: 913931
top: 64.00000000
bottom: 0.00000000
nsres: 2
nsres3: 2
ewres: 2
ewres3: 2
tbres: 8
rows: 594
rows3: 594
cols: 570
cols3: 570
depths: 8
Helena
Michael
C. Michael Barton
Helena,
Helena
Michael
C. Michael Barton
wrote:
Hi Michael,
Hi Anna,
It should be here
too.
Anna
[1] The Qt Project
Thanks
Michael
C. Michael Barton
Hi Michael,
workaround.
Anna
Michael
C. Michael Barton
grass-dev Info Page
