[GRASS-dev] [release planning] GRASS GIS 7.0.6
given the important ctypes/GCC 7 fix in trac #3331 I suggest to also
release GRASS GIS 7.0.6 (currently unplanned).
The related milestone is this one:
https://trac.osgeo.org/grass/milestone/7.0.6
Given the fact that in general we rather concentrate on 7.2.x releases
(or even higher version numbers), I'd keep this 7.0.6 maintenance
release as simple as possible.
If there aren't any objections, I'll start to prepare things :slight_smile:
On Sun, Jun 25, 2017 at 9:15 PM, Markus Neteler <neteler@osgeo.org> wrote:
has this been properly tested on all supported platforms?
I suggest to also
are there any features in 7.0 that are not present or not working in 7.2?
If not, I would rather encourage users to upgrade to 7.2.y instead of providing a new 7.0.y release.
Some bug fixes might have been backported from trunk to relbr72, but not to relbr70. These would need to be backported to relbr70 as well.
my2c
Markus M
(or even higher version numbers), I’d keep this 7.0.6 maintenance
If there aren’t any objections, I’ll start to prepare things :slight_smile:
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Jun 25, 2017 10:12 PM, ā€œMarkus Metzā€ <markus.metz.giswork@gmail.com> wrote:
So far on Mac, Windows, Fedora, and OpenSUSE.
I suggest to also
The problem is that GRASS will be kicked out of Fedora since it does not compile on F26. Likewise in similar modern distros where no update to 7.2 happens for whatever reason.
Not sure… We may keep it to a minimum to avoid above mentioned mess. it took so long to get accepted…
Best.
markusN
my2c
Markus M
I suggest to also
That means, some distros would update GRASS from 7.0.5 to 7.0.6 but not to 7.2.2? Weird.
Sounds like both a new 7.0 and a new 7.2 should be released soon.
Markus M
Best.
markusN
my2c
Markus M
On Mon, Jun 26, 2017 at 2:49 PM, Markus Metz
7.2.2? Weird.
AFAIK their rationale is to introduce major updates only within a full
distro release cycle.
However, I am just guessing here, extrapolating from what I observed
in Fedora and Debian.
IMHO yes.
markusN
7.2.2? Weird.
In Debian, it's mostly a question of timing between Debian freeze for a new release and our releases. The new stable was released a week ago with 7.2.0-2, and Debian testing has 7.2.1-1.
Moritz
On Mon, Jun 26, 2017 at 3:54 PM, Moritz Lennert
to 7.2.2? Weird.
FWIW, I got 7.2.1 into Fedora yesterday via maintainer Devrim Gündüz
(my updated SPEC file + ctypes patch):
https://koji.fedoraproject.org/koji/packageinfo?packageID=1972
:slight_smile:
Ok, back to the topic:
If the majority of grass-devs thinks that a 7.0.6 release is not
needed, I'm ok with that. Maintainers just need to understand that the
final patch from #3331 is needed to compile with GCC 7.
markusN
Of course we can release 7.0.6., still I wouldn't expect any distro
already shipping 7.0 to "upgrade" GCC to 7 without upgrading the rest
of packages, as GCC 7 would break not only GRASS GIS.
At the end it is call for the release manager (Markus?) to decide if
he's into packaging et al.
Māris.
2017-06-27 12:49 GMT+03:00 Markus Neteler <neteler@osgeo.org>:
to 7.2.2? Weird.
:slight_smile:
markusN
I would say that we leave it to distro maintainers to apply the existing patch if they really need it.
Moritz
Māris.
to 7.2.2? Weird.
:slight_smile:
markusN
Well, distros update compiler versions from time to time.
If the individual packages can cope with that is a separate issue...
Interest is low :slight_smile:
Of course we can release 7.0.6., still I wouldn’t expect any distro
already shipping 7.0 to ā€œupgradeā€ GCC to 7 without upgrading the rest
If the individual packages can cope with that is a separate issue…
he’s into packaging et al.
Should relbr70 be further maintained or are we focussing on relbr72 and trunk?
Markus M
Hi Devs,
On Thu, Jul 13, 2017 at 8:45 AM, Markus Metz
trunk?
Here the unpublished changes as one-liners:
https://trac.osgeo.org/grass/log/grass/branches/releasebranch_7_0?action=stop_on_copy&mode=stop_on_copy&rev=72287&stop_rev=69637&limit=400
and expanded:
https://trac.osgeo.org/grass/changeset?reponame=&new=72182%40grass%2Fbranches%2Freleasebranch_7_0&old=69637%40grass%2Fbranches%2Freleasebranch_7_0
As mentioned elsewhere, I volunteer for packaging 7.0.6 without extra
efforts, i.e.: tagging, tarball, CMS + trac update, done.
markusN
2018-03-01 15:16 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
I can do release by tomorrow. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Good, I can tag and package 7.0.6 tonight.
Ā·Ā·Ā·
Am 01.03.2018 5:09 nachm. schrieb ā€œMartin Landaā€ <landa.martin@gmail.com>:
Martin Landa
GRASS GIS 7.0.6 now got "silently" released:
https://trac.osgeo.org/grass/wiki/Release/7.0.6-News
No big announcement planned :slight_smile:
Thanks to all contributors!
2018-03-01 22:42 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
I will build at least standalone installer for Windows. Also prepared
copy-paste announcement [1].
Ma
[1] https://grass.osgeo.org/grass_admin/moduleinterface.php?mact=News,m1_,editarticle,0&_sx_=6f9d79485418a286&m1_articleid=73
Martin Landa
2018-03-02 10:10 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
published, https://grass.osgeo.org/news/73/15/GRASS-GIS-7-0-6-released/
Only standalone WinGRASS binaries uploaded. Ma
Martin Landa
