As for the changes in g.extension, I think they are necessary as e.g. here:
“grass7” is hardcoded in the URL.
A solution would be to first check if the “source_url” with “grass7”
(https://github.com/OSGeo/grass-addons/tree/master/grass7/) exists and otherwise assign the new URL without “grass7”.
As Vasek points out, first a decision has to be made about the final URL (or branch) in
https://github.com/OSGeo/grass-addons/issues/528
Here:
https://github.com/OSGeo/grass/pull/1678
is a draft PR for a possible approach to this. It may have to be backported to 7.6 or even 7.4?
g.extension in G7.8 already supports branches, so if there will be a branch for different versions, that should be easy to adjust in g.extension.
We should probably wait a bit with restructuring the addon repo until a modified version of g.extension has been packaged for the most essential OS/distros at least…
See: https://repology.org/project/grass/versions
g.extension in G8 can then be streamlined to the new repo structure…
Stefan
From: grass-dev grass-dev-bounces@lists.osgeo.org On Behalf Of Vaclav Petras
Sent: torsdag 24. juni 2021 04:45
To: Markus Neteler neteler@osgeo.org
Cc: GRASS developers list grass-dev@lists.osgeo.org
Subject: Re: [GRASS-dev] [release planning] GRASS GIS 7.8.6
On Wed, Jun 23, 2021 at 7:58 AM Markus Neteler <neteler@osgeo.org> wrote:
Important question: with the planned Addon repo structure affect
g.extension of G7?
If we want to make backports from v8 to v7 addons easier, then we need to create another branch for v7 (besides the one for v8) and restructure v7 as we did v6 and will restructure the v8 branch.
The master branch would stay as a read-only legacy in this scenario. The alternative is leaving the master branch for v7.
