[GRASS-dev] [release planning] GRASS GIS 7.8.6
Open questions for anyone with Windows (Helli? Others?):
- Is g.extension failing for all add-ons or only for a few? A new
blocker or not?
winGRASS g.extension is failing for some of the addons where some encoding issues pops up.
but see https://github.com/OSGeo/grass/pull/1496#issuecomment-812447963
manually set PYTHONUTF8 in C:\OSGeo4W64\apps\grass\grass79\etc\env.bat
set PYTHONUTF8=1
set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python3.exe
then
g.extension extension=i.fusion.hpf
Downloading precompiled GRASS Addons <i.fusion.hpf>...
Fetching <i.fusion.hpf> from <http://wingrass.fsv.cvut.cz/grass79/x86_64/addons/grass-7.9.dev/i.fusion.hpf.zip&gt; (be patient)...
Updating extensions metadata file...
Updating extension modules metadata file...
WARNING: No metadata available for module 'constants'.
WARNING: No metadata available for module 'high_pass_filter'.
ERROR: Unable to read manual page: [Errno 2] No such file or directory: 'C:\\Users\\youruser\\AppData\\Roaming\\GRASS7\\addons\\docs\\html\\constants.html'
at least no fileinput.FileInput error anymore
g.extension works then with these encoding issue addons
this is based upon https://docs.python.org/3/using/windows.html#utf-8-mode
Windows still uses legacy encodings for the system encoding (the ANSI Code Page). Python uses it for the default encoding of text files (e.g. locale.getpreferredencoding()).
This may cause issues because UTF-8 is widely used on the internet and most Unix systems, including WSL (Windows Subsystem for Linux).
You can use UTF-8 mode to change the default text encoding to UTF-8.
I've tested a bit locally, g.extension works then (beside https://github.com/OSGeo/grass/issues/1499 , though that's a minor issue as all nested addons and helper libs are working, just a nasty warning ); (localized) GUI is mostly working.
though I have no idea if there are any possible side effects with set PYTHONUTF8=1 ....
maybe Anna, Maris have some ideas?
should we activate it in master and see what CI test are reporting?
kind regards
Helmut
