[GRASS-dev] [release planning] GRASS GIS 8.0.1
Hi devs,
Under certain circumstances (i.e., offline/sandbox compilation) the
recent 8.0.0 release causes troubles (see
https://github.com/OSGeo/grass/issues/2137).
This has been addressed and fixed since then.
Two blockers are still open (the second we already bumped from 8.0.0
to 8.0.1, not sure if they are blockers at all):
https://github.com/OSGeo/grass/issues?q=is%3Aopen+is%3Aissue+label%3Ablocker+milestone%3A8.0.1
Now, since backports to the future 8.0.2 are piling up (esp. the
ctypes related fix: https://github.com/OSGeo/grass/pull/2079), I would
suggest that we release 8.0.1 asap.
Hence I may prepare 8.0.1RC1 in the next day(s).
Any objections?
Best,
There’s also an email to grass-user reporting that extensions cannot be installed in Windows with GRASS 8 standalone installer. In the user report, it seems there was an issue with tags too as he reports that after installing the standalone the version he gets is 8.0.0dev. See the email here: https://lists.osgeo.org/pipermail/grass-user/2022-February/082861.html (Anna already asked him to file an issue).
If this is the case, it may become a blocker, IMO.
El mar, 8 feb 2022 a las 13:08, Markus Neteler (<neteler@osgeo.org>) escribió:
Hi devs,
Any objections?
Best,
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Tue, Feb 8, 2022 at 1:29 PM Veronica Andreo <veroandreo@gmail.com> wrote:
There's also an email to grass-user reporting that extensions cannot be installed in Windows with GRASS 8 standalone installer. In the user report, it seems there was an issue with tags too as he reports that after installing the standalone the version he gets is 8.0.0dev. See the email here: https://lists.osgeo.org/pipermail/grass-user/2022-February/082861.html (Anna already asked him to file an issue).
I saw that but it is a bit strange - to me it looks like a setup issue
on the winGRASS server.
I have notified Martin for that, let's see.
AFAIK this has been fixed.
As discussed in yesterday's PSC meeting, I have tagged GRASS GIS 8.0.1RC1:
https://github.com/OSGeo/grass/releases/tag/8.0.1RC1
Please test it!
And I hope we do not need a RC2...
Hi devs,
(8.0.1 milestone: https://github.com/OSGeo/grass/milestone/9)
I still see backport candidate(s) in
- https://github.com/OSGeo/grass/issues?q=is%3Aopen+is%3Aissue+label%3Abackport_needed+milestone%3A8.0.1
How to deal with that?
On Sun, Feb 20, 2022 at 2:06 PM Markus Neteler <neteler@osgeo.org> wrote:
Hi devs,
Empty now.
However, there are still a number of 8.0.1-labeled PRs open:
https://github.com/OSGeo/grass/issues?q=is%3Aissue+milestone%3A8.0.1+is%3Aopen
How to deal with that? May all be bumped to 8.0.2?
Hi devs,
Empty now.
I moved anything inactive for more than two weeks to 8.0.2 (both issues and PRs). I don’t think we need to have any discussion to do that.
I also moved to 8.0.2 any PRs with a missing review. 1 PR by MarkusM didn’t have the backport label and looked like material for a future minor release (moved to 8.2). No PRs remain.
3 issues related to Windows remain (generally, unresolved issues without blocker label should be moved before release, but perhaps some of these are solved since there is activity today?).
https://github.com/OSGeo/grass/pulls?q=is%3Aopen+is%3Apr+milestone%3A8.0.1+sort%3Aupdated-desc
https://github.com/OSGeo/grass/issues?q=is%3Aopen+is%3Aissue+milestone%3A8.0.1+sort%3Aupdated-desc
so 12. 2. 2022 v 17:39 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
Please test it!
sorry for delay, here is standalone installer:
https://grass.osgeo.org/grass80/binary/mswindows/native/WinGRASS-8.0.1RC1-1-Setup.exe
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
> Hi devs,
Empty now.
All bumped to 8.0.2, so we are good.
Here the changes since RC1 for final inspection:
https://github.com/OSGeo/grass/compare/8.0.1RC1...releasebranch_8_0
If there are no objectives, I'll prepare 8.0.1 final tonight.
čt 24. 2. 2022 v 10:36 odesílatel Markus Neteler <neteler@osgeo.org> napsal:
+1 Martin
Martin Landa
+1
Huidae
Huidae Cho, Ph.D., GISP, /hidɛ t͡ɕo/, 조희대, 曺喜大
GRASS GIS Developer
https://idea.isnew.info/
Hi devs,
GRASS GIS 8.0.1 is out:
Means: backporting from main to milestone 8.0.2 can start!
