[GRASS-dev] releasebranch_6_4 Arch PKGBUILD - review
I'm attaching my Arch PKBUILD for GRASS releasebranch_6_4. Can you guys
please have a good look if there is anything wrong, missing, could be
done better/neater (including comments too)?
I'm going to come up with similar PKBUILDs for develbranch_6, trunk and
most recent 6.4 RC as well, and publish them all on AUR
(https://aur.archlinux.org), so that it's easy to have multiple, uniform
GRASS versions installed in parallel on Arch.
There are a couple of GRASS PKBUILDs in AUR already, but some of them
conflict each other, have different sets of build options enabled and
they mess with the source more than really needed.
BTW: Will the TK 8.6 fix
http://trac.osgeo.org/grass/ticket/1843#comment:8 be applied to
releasebranch_6_4 and releasebranch_6?
Maciek
Maciej Sieczka
http://www.sieczka.org
(attachments)
grass64.PKGBUILD.sh (6.47 KB)
I have uploaded PKGBUILDs for releasebranch_6_4, develbranch_6 and trunk
to AUR [1]. Latest 6.4 RC comes soon.
They can be co-installed.
Any improvement suggestions are welcome.
Can I maintain them in GRASS SVN (each in its branch) and advertise on
http://grass.osgeo.org/download/software/linux/?
Maciek
[1] https://aur.archlinux.org/packages/?SeB=m&K=czk
W dniu 13.01.2013 01:03, Maciej Sieczka pisze:
guys please have a good look if there is anything wrong, missing,
could be done better/neater (including comments too)?
and most recent 6.4 RC as well, and publish them all on AUR
uniform GRASS versions installed in parallel on Arch.
them conflict each other, have different sets of build options
enabled and they mess with the source more than really needed.
Maciek
_______________________________________________ grass-dev mailing
list grass-dev@lists.osgeo.org
Maciej Sieczka
On Sun, Jan 13, 2013 at 1:03 AM, Maciej Sieczka <msieczka@sieczka.org> wrote:
MarkusM has done this recently.
MarkusN
(removing grass-user to avoid too much cross-posting)
On Mon, Jan 28, 2013 at 12:10 AM, Maciej Sieczka <msieczka@sieczka.org> wrote:
You mean the build script? For the other distros it is on their servers.
and advertise on
Added. But I would need to know the install command to add it as for the
other distros.
W dniu 29.01.2013 22:25, Markus Neteler pisze:
<msieczka@sieczka.org> wrote: ...
servers.
OK.
and advertise on http://grass.osgeo.org/download/software/linux/?
Added.
Thanks. Can you change "archlinux" to "Arch Linux", as they call them
themself?
other distros.
There is no single command. The instructions are on
https://wiki.archlinux.org/index.php/AUR_User_Guidelines#Installing_packages.
Maciek
Maciej Sieczka
On Wed, Jan 30, 2013 at 12:25 AM, Maciej Sieczka <msieczka@sieczka.org> wrote:
themself?
Sure, done.
other distros.
OK, I have used that URL.
W dniu 30.01.2013 08:27, Markus Neteler pisze:
themself?
Sure, done.
other distros.
Looks OK. Thank you.
Maciek
Maciej Sieczka
