[GRASS-dev] Remaining shell scripts
The following is a list of remaining shell scripts (or files which
"file" thinks are shell scripts), not including those which are
clearly only used for building or testing:
  gui/scripts/d.path.sh
  gui/wxpython/scripts/p.cmd
  gui/wxpython/scripts/p.db
  gui/wxpython/scripts/p.mon
  gui/wxpython/scripts/p.rast
  gui/wxpython/scripts/p.vect
  lib/init/grass-xterm-mac
  lib/init/grass.src
  lib/init/html_browser_mac.sh
  lib/init/init.sh
  lib/init/prompt.sh
  macosx/app/build_gui_user_menu.sh
  macosx/app/build_html_user_index.sh
  macosx/app/grass.sh.in
  macosx/pkg/resources/postflight.in
  raster/r.li/r.li.setup/area_query
  raster/r.li/r.li.setup/masked_area_selection
  raster/r.li/r.li.setup/r.li.setup
  raster/r.li/r.li.setup/r.li.setup.main
  raster/r.li/r.li.setup/sample_area_vector.sh
  raster/r.li/r.li.setup/square_mouse_selection.sh
  raster/r.li/r.li.setup/square_query
  scripts/d.out.gpsdrive/d.out.gpsdrive
  scripts/d.vect.thematic/d.vect.thematic
  scripts/r.mapcalculator/r.mapcalculator
  scripts/r3.mapcalculator/r3.mapcalculator
  scripts/v.in.garmin/v.in.garmin
  scripts/v.in.gpsbabel/v.in.gpsbabel
  scripts/v.out.gps/v.out.gps
  visualization/nviz/scripts/nviz
Which ones need to be ported to Python, which ones can be removed,
which ones should stay (with reasons)?
run. variation on tools html script to make help index and gui menu for external addons. Probably should be rewritten.
run. This could be rewritten, I need to catch up with what's going on with the startup.
Mac distribution. leave as shell script.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
