[GRASS-dev] Remaining shell scripts
On Jun 19, 2009, at 6:49 AM, grass-dev-request@lists.osgeo.org wrote:
       scripts/d.vect.thematic/d.vect.thematic
Needs to be rewritten into Python (at least for points/lines) because the current C module only does areas.
       scripts/r.mapcalculator/r.mapcalculator
Already replaced in python. Can be discarded
       scripts/r3.mapcalculator/r3.mapcalculator
Needs to be replaced. Can model after new wxpython map calculator
       scripts/v.in.garmin/v.in.garmin
       scripts/v.in.gpsbabel/v.in.gpsbabel
       scripts/v.out.gps/v.out.gps
Need to be ported to python
       visualization/nviz/scripts/nviz
Need to port to python and keep until wxpython 3Dviz is completed.
Michael
2009/6/19 Michael Barton <michael.barton@asu.edu>:
  scripts/d\.vect\.thematic/d\.vect\.thematic
Probably better to extent C module rather then porting to Python.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On 19/06/09 17:59, Martin Landa wrote:
+1 I know I promised this long ago, and just haven't been able to deliver. Sorry.
I do have some half-ready stuff on my machine. AFAIR main.c is more or less done and I just need to finish the actual plotting routines. But I will definitely not get to this before the end of July. If anyone else wants to take a look, I can send you the code in its current state.
d.thematic.area also needs much more testing...
Moritz
2009/6/19 Moritz Lennert <mlennert@club.worldonline.be>:
Sorry.
probably better to submit to SVN...
Martin
