Michael wrote:
The TclTk GUI is set to be abandoned in GRASS 7. It will continue to
live in the GRASS 6 series.
last call for objections before the Tcl/Tk gis.m is removed from GRASS 7.
(trunk/gui/tcltk/)
Hamish
(trunk/gui/tcltk/)
Hamish
> live in the GRASS 6 series.last call for objections before the Tcl/Tk gis.m is removed from GRASS 7.
(trunk/gui/tcltk/)
Not an objection, but is the wx GUI sufficient? Bear in mind that
XDRIVER has already disappeared from 7.0, so the GUI is even more
important in 7.0 than in 6.x.
Hi all.
I suppose removing tcltk interface will make it impossible to run some
commands, such as r.li, right?
All the best.
pc
Paolo Cavallini
http://faunalia.it/pc
No. You need Tcl/Tk for r.li.setup, but you don't need gis.m (the
Tcl/Tk GUI).
However, r.li.setup does need lib/gtcltk.
