[GRASS-dev] removing gis.m from GRASS 7
On Oct 14, 2008, at 8:10 AM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Tue, 14 Oct 2008 13:46:16 +0200 (CEST)
Subject: Re: [GRASS-dev] removing gis.m from GRASS 7
To: "Glynn Clements" <glynn@gclements.plus.com>
Cc: grass-dev <grass-dev@lists.osgeo.org>
Message-ID:
  <9b731893b11bc4987f4438b8878350d9.squirrel@www.faunalia.it>
Content-Type: text/plain;charset=iso-8859-1
Not an objection, but is the wx GUI sufficient?
Hi all.
I suppose removing tcltk interface will make it impossible to run some
commands, such as r.li, right?
All the best.
The only thing that is needed is for the setup script to be ported to wxPython. The rest of the r.li modules should run as is.
Michael
