[GRASS-dev] removing small multiple polygons created by r.stream.basin + r.to.vect
when I delineate a basin using r.stream.basins, and convert the raster map of the basin into vector (r.to.vect), I sometimes get multiple polygons: i.e. one bigger and a couple of one cell polygons. (you can reproduce the behavior in NC sample dataset using easting=643677.87 northing=222800.246).
Since i need to remove the small polygons in a script, I would like to know whether I can use:
grass.run_command(‘v.extract’, list = 1,
input = v_basins,
output = v_basin,
type = ‘area’,
overwrite = True)
In fact, it seems to me that the bigger polygon is always listed as the first record. Is that always true? Does r.to.vect (feature=area) always list as first record the polygon with the larger area?
Or else, I should set a SQL query about the area. I’ve already tried something like:
grass.run_command(‘v.extract’, where = ‘area = max(area)’,
input = v_basins,
output = v_basin,
type = ‘area’,
overwrite = True)
but it seems that the SQL statement is incorrect … I’m not experienced with SQL.
Any idea?
madi
Ing. Margherita Di Leo, Ph.D.
On Mon, Apr 9, 2012 at 3:39 PM, Margherita Di Leo
<dileomargherita@gmail.com> wrote:
whether I can use:
    grass\.run\_command\(&#39;v\.extract&#39;, list = 1,
Wouldn't it be better to remove them with v.clean and rmarea to avoid holes?
Ciao Markus,
On Mon, Apr 9, 2012 at 3:47 PM, Markus Neteler <neteler@osgeo.org> wrote:
Wouldn’t it be better to remove them with v.clean and rmarea to avoid holes?
just tried with:
grass.run_command(‘v.clean’, input = v_basins,
output = v_basin,
type = ‘area’,
tool = ‘rmarea’,
thresh = 1, # I also tried 10
overwrite = True)
Maybe I do something wrong, but this way I can’t get rid of small polygons, and, in addiction, I need to set the threshold parameter, which I’m not sure to be suitable for all cases…
where am I wrong?
madi
On Mon, Apr 9, 2012 at 4:25 PM, Margherita Di Leo
Ciao Markus,
holes?
just tried with:
    grass\.run\_command\(&#39;v\.clean&#39;, input = v\_basins,
                                 output = v\_basin,
                                 type = &#39;area&#39;,
                                 tool = &#39;rmarea&#39;,
                                 thresh = 1,     \# I also tried 10
                                 overwrite = True\)
Maybe I do something wrong, but this way I can't get rid of small polygons,
what is exactly happening? Nothing or some are removed?
and, in addiction, I need to set the threshold parameter, which I'm not sure
to be suitable for all cases...
I wanted to suggest to run quartile statistics (extended stats in v.univar) on
an "area" column (if needed, add with v.to.db). But I realized that it only
supports extended statistics on point data :frowning: No idea why this limitation...
So I thought to suggest the 1st quartile as threshold.
Maybe someone else has an idea?
Ciao Markus,
holes?
just tried with:
output = v_basin,
type = ‘area’,
tool = ‘rmarea’,
overwrite = True)
In this case, nothing is removed. I’ll give it some more try…
an “area” column (if needed, add with v.to.db). But I realized that it only
supports extended statistics on point data :frowning: No idea why this limitation…
Thanks, I’ll work on this idea.
On Mon, Apr 9, 2012 at 6:43 PM, Margherita Di Leo <dileomargherita@gmail.com> wrote:
Ciao Markus,
holes?
just tried with:
output = v_basin,
type = ‘area’,
tool = ‘rmarea’,
overwrite = True)
Looks like small areas are removed, but the table associated to the vector map is not updated, hence the records of the small areas are still present (cat = 2 and cat = 3). My error? What am I missing?
The one-cell areas are correct, at least within the logic of vector
topology. If you used r.to.vect with the -v flag, the one-cell areas
will have the same category like the neighboring areas belonging to
the same basin, that is, area calculations for basins done with
v.to.db will be correct and all areas belonging to the same basin will
share the same category (row in the attribute table).
If you want to remove one-cell areas with v.clean tool=rmarea, the
threshold should obviously be larger than the area of one cell (nsres
* ewres) of the original raster and smaller than two cells (2 * nsres
* ewres).
If you want to get rid of entries in the attribute table that are no
longer linked to a vector feature, you can use v.extract layer=1
type=area for areas in layer 1 or alternatively check the min and max
category values with v.category op=report and then v.extract
list=min-max.
Markus M
On Mon, Apr 9, 2012 at 7:35 PM, Margherita Di Leo
> Ciao Markus,
>> holes?
> just tried with:
> grass.run_command('v.clean', input = v_basins,
> output = v_basin,
> type = 'area',
> tool = 'rmarea',
> overwrite = True)
> polygons,
In this case, nothing is removed. I'll give it some more try..
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Markus,
On Mon, Apr 9, 2012 at 8:09 PM, Markus Metz <markus.metz.giswork@googlemail.com> wrote:
I think this is my case… Thanks a lot!
madi
