I was trying to render some maps automatically but I’m having problems with setting the size of the image. I set size like this:
export GRASS_RENDER_HEIGHT=1350
export GRASS_RENDER_WIDTH=1500
But with cairo I get still the default size:
d.mon cairo
d.rast aspect
map.png size is now 640x480
d.mon stop=cairo
With png I get an error:
d.mon png
d.rast aspect
ERROR: PNG: input file has incorrect dimensions: expected: 640x480 got:
1500x1350
map.png is now empty but it has the correct size
d.mon stop=png
With wx0 I get the error but also an image in GUI. The main GUI works without any errors. I observe same behavior in 70 branch and when using height and width parameters of d.mon. I exited the session and started again.
Any idea what’s happening or what should I try?
Vaclav
On 01/05/15 05:24, Vaclav Petras wrote:
I was trying to render some maps automatically but I'm having problems
d.mon cairo
d.rast aspect
# map.png size is now 640x480
d.mon stop=cairo
d.mon png
d.rast aspect
1500x1350
# map.png is now empty but it has the correct size
d.mon stop=png
I have a vague memory that such an error occurs when you have an existing map.png file in the current directory with dimensions different from the ones you set.
Moritz
On Sat, May 2, 2015 at 12:13 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Again for cairo:
$ mkdir abc1
$ cd abc1
$ export GRASS_RENDER_HEIGHT=1350
$ export GRASS_RENDER_WIDTH=1500
$ g.region raster=elevation
$ d.mon cairo
Output file: …/abc1/map.png
$ d.rast elevation
map.png: PNG image data, 640 x 480, 8-bit/color RGB, non-interlaced
(image contains elevation in 640 x 480)
The same for SVG:
<svg … width=“640pt” height=“480pt” viewBox=“0 0 640 480” version=“1.1”>
<image id=“image5” width=“640” height=“480”…
and also PDF.
And again for png:
$ mkdir abc2
$ cd abc2
$ d.mon png
Output file: …/abc2/map.png
$ d.rast elevation
1500x1350
map.png: PNG image data, 1500 x 1350, 8-bit/color RGBA, non-interlaced
(image contains nothing but has 1500 x 1350)
I’ve tried to use an empty directory but no effect. So this is not the case. According to this test it seems that PNG driver does not work at all with different height and width, is that even possible?
Vaclav
Moritz
Again for cairo:
$ mkdir abc1
$ cd abc1
$ d.mon cairo
Output file: .../abc1/map.png
$ d.rast elevation
Confirmed for trunk.
Indeed, in relbranch70 I get
GRASS 7.0.1svn (nc_spm_08_grass7):~ > export GRASS_RENDER_HEIGHT=1350
GRASS 7.0.1svn (nc_spm_08_grass7):~ > export GRASS_RENDER_WIDTH=1500
GRASS 7.0.1svn (nc_spm_08_grass7):~ > d.mon start=png
ERROR: PNG: input file is not RGBA
# trying harder:
GRASS 7.0.1svn (nc_spm_08_grass7):~ > echo $GRASS_RENDER_TRUECOLOR
GRASS 7.0.1svn (nc_spm_08_grass7):~ > export GRASS_RENDER_TRUECOLOR=TRUE
huh?
2015-05-01 5:24 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
I was trying to render some maps automatically but I'm having problems with
d.mon cairo
d.rast aspect
d.mon stop=cairo
please try out r65178. d.mon should respect GRASS_RENDER_HEIGHT and
GRASS_RENDER_WIDTH if `width/height` is not set.
d.mon png
d.rast aspect
1500x1350
d.mon stop=png
Should be also fixed. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
2015-05-03 7:22 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
input image has been apparently created by cairo. Try to delete file
before starting png display driver. Martin
Martin Landa
On Sun, May 3, 2015 at 12:11 PM, Martin Landa <landa.martin@gmail.com> wrote:
Good catch! I though I had deleted it...
GRASS 7.0.1svn (nc_spm_08_grass7):~ > rm -f map.png
Output file: /home/neteler/map.png
GRASS 7.0.1svn (nc_spm_08_grass7):~ > d.rast aspect
GRASS 7.0.1svn (nc_spm_08_grass7):~ > d.mon stop=png
GRASS 7.0.1svn (nc_spm_08_grass7):~ > file map.png
map.png: PNG image data, 640 x 480, 8-bit/color RGBA, non-interlaced
### now testing latest trunk changes:
GRASS 7.1.svn (nc_spm_08_grass7):~ > file map.png
... the latest change helps: seems to work now.
thanks
Thanks Martin, with r65183 most of the things work. With environmental
variables both PNG and Cairo drivers worked, i.e. the size was appropriate.
Options width and height worked for Cairo but not for PNG:
ls
(nothing)
d.mon png width=1500 height=1350
d.rast elevation
ERROR: PNG: input file has incorrect dimensions: expected: 1500x1350 got:
640x480
And the file is empty (white).
I also tested the default settings for Cairo and it (correctly) gives
640x480 image.
2015-05-04 2:47 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
d.rast elevation
640x480
I cannot reproduce this behavior:
d.mon png w=1000 h=500 out=/tmp/png.png
d.rast dmt --v
png: image size 1000x500
Probably map.png has been created by cairo driver? Ma
Martin Landa
On Mon, Mar 28, 2016 at 2:53 PM, Martin Landa <landa.martin@gmail.com>
> d.rast elevation
> 640x480
d.rast dmt --v
Works with output.
d.mon png width=1500 height=1350 output=/tmp/png.png
d.rast elevation --v
Using display driver <png>...
png: truecolor status enabled
png: collecting to file '/tmp/png.png'
png: image size 1500x1350
But using the default file name it fails:
png: collecting to file '/.../map.png'
640x480
When I use file command:
ls
[nothing]
No sure how this works but I'm not starting cairo at the same time.
Thanks for getting back to this,
Vaclav
2016-03-28 21:12 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
should be fixed in r68197. Ma
Martin Landa
