[GRASS-dev] reorder tcltk/opengl checks in configure?
William wrote:
I'm trying to fiddle with configure.in to figure out what
to do for tcltk 64bit aqua. When I run autoconf (in dev6
branch) I get:
configure.in:47: error: possibly undefined macro:
AC_MSG_ERROR
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
Configure is generated, though it's twice the size of the
configure in SVN. But it dies with a syntax error.
Is there anything special I need to do?
I have autoconf 2.61, which comes with the Xcode
installation. I don't want to mess with it to update
it, if that's what's needed.
... but can you downgrade it? often it might already be around
as autoconf2.13.
from the top of configure.in:
# Note: use autoconf-2.13
Hamish
There's only the 2.61 from Xcode. Is that 2.13 an absolute requirement or a minimum? I don't see why a newer autoconf shouldn't support an older configure.in.
I tried the more complete sequence of aclocal/autoheader/automake/autoconf, but got a bunch of missing template warnings in autoheader.
branch) I get:
AC_MSG_ERROR
as autoconf2.13.
Hamish
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
On Sat, May 23, 2009 at 5:40 AM, William Kyngesburye
configure.in.
Because it is autoconf :slight_smile:
I darkly remember that I made tests with 2.51 but quickly gave up.
2.13 seems to be an absolute requirement.
I could try installing autoconf 2.13 in a sandbox, so it leaves Xcode alone...
configure.in.
grass-dev mailing list
grass-dev@lists.osgeo.org
The equator is so long, it could encircle the earth completely once.
The former.
configure.in.
Later versions aren't backwards compatible.
2.13 was the last version before autotools degenerated into an
incomprehensible mess.
OK, I installed an isolated 2.13 and it works as expected. I guess I'll keep it around for GRASS.
I updated configure[.in] + some makefiles in dev6 branch so that configure + compile works on OSX for a 64bit build with a 32bit TclTk Aqua.
Configure was a bit messy, since the saving of LDFLAGS happens within the AC test macro.
configure.in.
"Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
PS. That's r37402
http://trac.osgeo.org/grass/changeset/37402
- Ford Prefect
