Dear all,
I would like to remove the line 680:
get_msgr().debug(1, self.get_bash())
from the run method of the Module class.
I would like to remove it because the get_msgr is using ctypes (grass.lib.gis),
this it means that all the LD_LIBRARY_PATH must be set correctly.
Set the LD_LIBRARY_PATH could be a problem, for example if you try to use
the class from QGIS, because it require to launch QGIS with something like;
#!/usr/bin/sh
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$GISBASE/lib \
PATH=$PATH:$GISBASE/bin:$GISBASE/scripts:$HOME/.grass7/addons/bin:$HOME/.grass7/addons/scripts
PYTHONPATH=$PYTHONPATH:$GISBASE/etc/python:$GISBASE/gui/wxpython \
GRASS_ADDON_BASE=$HOME/.grass7/addons qgis
On the other hand, I understand that we need the debug. therefore I
was thinking to provide the same functionalities but avoiding to call
directly the G_debug functions, G_debug is define as follow:
int G_debug(int level, const char *msg, ...)
char *filen;
va_list ap;
FILE *fd;
G_init_debug();
if (grass_debug_level >= level) {
va_start(ap, msg);
filen = getenv("GRASS_DEBUG_FILE");
if (filen != NULL) {
fd = fopen(filen, "a");
if (!fd) {
G_warning(_("Cannot open debug file '%s'"), filen);
return 0;
else {
fd = stderr;
fprintf(fd, "D%d/%d: ", level, grass_debug_level);
vfprintf(fd, msg, ap);
fprintf(fd, "\n");
fflush(fd);
if (filen != NULL)
fclose(fd);
va_end(ap);
return 1;
and I'm defining a function (probably is still too simple) such as:
from __future__ import print_function
import os
import sys
def get_env():
gisrc = os.environ.get('GISRC')
if gisrc is None:
raise RunError('You are not in a GRASS session')
with open(gisrc, mode='r') as grc:
env = {k.strip(): v.strip() for k, v in [row.split(':') for
row in grc if row]}
return env
def get_debug_level():
debug = get_env().get('DEBUG')
return int(debug) if debug else 0
def G_debug(level, *msg):
debug_level = get_debug_level()
if debug_level >= level:
dfile = os.environ.get("GRASS_DEBUG_FILE")
fd = sys.stderr if dfile is None else open(dfile, mode='a')
print("D%d/%d: " % (level, debug_level), *msg, end='\n', file=fd)
Concerning the performance of course the python version is slower but
only 6 times:
%timeit G_debug_python(5, 'provami...')
The slowest run took 9.75 times longer than the fastest. This could
mean that an intermediate result is being cached
100000 loops, best of 3: 13.8 µs per loop
In [25]: %timeit G_debug_grass(5, 'provami...')
The slowest run took 32.00 times longer than the fastest. This could
100000 loops, best of 3: 2.35 µs per loop
But in this way the ctypes are not required by the pygrass.modules
classes and functions.
What do you think?
Other ideas and/or solutions?
Best regards
Pietro
