Martin,
After a double click on a vector layer (or right click > properties) and
trying to select another vector map, wxGUI often quits and in dmesg a
following segfault info is present:
python[15959]: segfault at d300000088 ip 7f8def940d91 sp 7ffffa9102b0
error 4 in libwx_gtk2u_core-2.8.so.0.5.0[7f8def5ef000+3f1000]
I can reproduce the error sometimes at a first attempt, sometimes it
takes 2 or 5, but finally wxGUI crashes.
I realize it's not a crash in wxGUI, thus I'm not reporting it to Trac,
but maybe you know how to avoid it.
Debian testing amd64, python-wxgtk 2.8.8.1, develbranch6 r32363.
Maciek
Maciej Sieczka
www.sieczka.org
2008/7/30 Maciej Sieczka <tutey@o2.pl>:
I can confirm it, sometimes wxGUI crashes also on my machine. No idea
here. I will try to investigate a bit.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
