[GRASS-dev] Report #4, GSoC, GRASS Image Segmentation
TGIF!
It is fun to be into the guts of the coding.
Completed:
  • Segmentation will run on tiny maps, using arrays. This demonstrated algorithm steps are sound, resulting segments were correct.
  • Started to implement some linked lists to increase the size of the map that can be processed.
Next week:
  • Finish linked list implementation.
  • Add polygon constraints for preexisting segmentation boundaries.
Blocking:
Nothing has stopped me for very long, I continue to have great support from my mentors. My challenge this week (well, I suppose this is a common challenge!) was balancing the urge to write fast and finish large chunks of code against taking the time to test and proceed carefully to avoid introducing bugs.
Eric
