On Sep 25, 2011, at 8:17 AM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Sat, 24 Sep 2011 13:46:37 +0200
Subject: Re: [GRASS-dev] requring explicit input=-
To: Hamish <hamish_b@yahoo.com>
Cc: grass-dev@lists.osgeo.org
Message-ID:
<CA+Ei1Oc1hE7+gc8HYVCfEek_16_tTcs7eKJHup2W0efPi=5T-g@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-12011/9/24 Hamish <hamish_b@yahoo.com>:
re. r48434 ?(and a number of other places)
it's a PITA to have to type input=- all the time from the command
line in places where it can be readily inferred.well, I don't think that it's a PITA, it's just a little bit more
typing, in this case `i=-` Personally I would incline to force
user to define that stdin should be read. It leads to the more
readable module interface and probably less confusing for CLI
newcomers. What's your opinion, GRASS power users?
Date: Sat, 24 Sep 2011 16:34:00 +0200
Subject: Re: [GRASS-dev] Re: requring explicit input=-
Message-ID:
<CA+Ei1Od6c-PtN-qy1KuK5ZVAoutGKM9Fj3=Qjr=Q5-krjapTRA@mail.gmail.com>
can anyone think of a case where "-" would ever be used as an
arbit'rary string, not meaning stdin?
I guess it is a similar probability to someone wanting to use a
literal "-" as a file or map name. g.message is all I can think
of, but that's not used in the gui menu.I don't know, anyway this rude check can be always replaced by full
check (gtask.parse_command/interface). wxGUI is quite over-complicated
(too much commands running on the background), let's try a simple
check first (without checking type of the options).
I agree with Martin in both cases.
Michael
