hello,
I search the function which cut a raster part according to limits given by a vector (polygon). These two features are within the same projection.
thanks a lot
hello,
thanks a lot
Hi Quentin,
If your vector contains a single polygon, I would do it this way :
* v.to.rast (with the option type=area)
* then assign the result to a mask with r.mask
* finally run r.mapcalc on your raster with a simple identity
(outrast=inrast)
Le mardi 14 avril 2009 à 17:43 +0200, Quentin Page a écrit :
hello,
by a vector (polygon). These two features are within the same projection.thanks a lot
grass-dev mailing list
grass-dev@lists.osgeo.org
