the modules can generate reStructuredText description of the interface. If I remember correctly, it is not used anywhere now but it could be advantageous for some cases, so I would definitively keep it. From g.parser manual page:
reStructuredText (REST)
The flag --rest-description added to a GRASS command generates a related help page template in reStructuredText. Example:
v.in.db --rest-description
However, --rest-description is misleading since it usually refers to REST (Representational state transfer) rather than to reStructuredText. So, I would suggest to change --rest-description to --rst-description. “rst” is a suffix commonly used for reStructuredText files (used also in GRASS GIS). Anybody against the change?
2014-12-22 4:06 GMT+01:00 Vaclav Petras <wenzeslaus@gmail.com>:
would suggest to change --rest-description to --rst-description. "rst" is a
not all, I would highly agree with this change. Martin
On Thu, Dec 25, 2014 at 1:17 PM, Martin Landa <landa.martin@gmail.com>
wrote:
is a
Implemented in r63780 but just the rename. Unfortunately, I cannot replace
all occurrences of "rest" (as in reStructuredText) in the source code now.
Anyway, we should get back to this topic. There is a lot of code
related to reStructuredText
in GRASS and it might be quite useful for different things.
