Hello everybody,
This is resubmition from my previous post.
When we run any algorithms of network analysis, it works on a structure dglGraph_s . This structure represents graph consiting of nodes ( vertices) and arcs between. It also put forward access cost , backward access cost and node cost on this. This is what i have understood through code walkthrough. There are various fields in this structure and similar ones related to this.
In my application , i want to access use such graph which is available to
me in form of struct dglGraph_s. This gets populated when i run Vect_net_build_graph(). But i am not able to comprehend what various field in this struture signify. I mean how i can acess various nodes and which arcs are connecting them.
If anyplace my understanding is not correct, kindly correct me
thanks
nitin
