[GRASS-dev] Retiling functionality for 2D raster?
for voxels, we have the r3.retile module to subset a volume:
http://grass.osgeo.org/grass70/manuals/r3.retile.html
I am lacking a "r.retile" module to easily split a big 2D raster
map into tiles, e.g. for parallelized analysis on a cluster.
To go the v.mkgrid way might be a bit tedious.
Any ideas? (Ab)use the segment lib to achieve this?
thanks,
r.tile added in r55511.
On Mon, Mar 25, 2013 at 3:55 AM, Glynn Clements
Wonderful, thanks.
How about renaming r3.retile to r3.tile (to gain name consistency)?
Wonderful, thanks.
They do different things. r3.retile generates a single output map, but
with the specified tiling (3d rasters are tile-based). r.tile
generates a separate raster for each tile (equivalent to running
g.region+r.resample in a double loop).
I found a small issue:
g.region rast=elevation -p
r.tile input=elevation output=elev_tile width=135 height=150
WARNING: category information for [elev_tile] in [user1] missing or invalid
Could that be fixed/suppressed?
thanks
