On Apr 9, 2007, at 3:56 AM, Glynn Clements wrote:
Can you not just run the command in a separate terminal instance, in
the same way that xterms are used?
Not quite. Problems (rehash from previous discussion):
- doesn't inherit env
So far as this part is concerned, I suggest writing out the
environment as a shell script, then sending e.g.
"source /path/to/env.sh" to the terminal, rather than sending
individual settings.
Interaction with Terminal.app from AppleScript is limited to sending commands inline. If I sent the temp script file first from the shell, then switched to AppleScript control, there is the problem that I might connect to the wrong Terminal window due to the Terminal's limited AppleScript capabilities.
- returns immediately, without waiting for command to finish
- leaves Terminal as active application, so one must manually switch
back to whatever called it (ie X11/Tcltk)
Can you create a new terminal, send it the command, wait for the
command to complete, then kill the terminal?
Sending environment settings to an existing terminal might cause
problems for what you were doing in that terminal.
The AppleScript part does this. AppleScript is needed to do the waiting. It also waits for the env commands, though just with a single delay (I may need to loop that for slow Macs).
Also, isn't there anything like xterm which uses the native GUI? Or is
there something about the nature of the GUI which makes that
impossible?
I saw an alternative recently, and it claims xterm compatibility. It's in beta right now. One small problem is requiring/suggesting yet another extra on a user's system.
But mainly, I can't understand how the xterm compatibility part would work: to be able to handle the xterm flags, it has to be able to run from the CLI, but when run from the CLI an application executable opens a completely new instance of the whole application, not a new window (exactly the same problem as the browser issue I'm working on).
The open method which is necessary operates on files, and doesn't have a way to pass arguments with that.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
