When copying via g.copy and specifying --overwrite and the target object
already exists, the return value is 1 but no error message is returned:
| simASM:grassAnalysis> g.copy --overwrite region=region1,region2
| simASM:grassAnalysis> echo $?
| 1
| simASM:grassAnalysis> g.version
| GRASS 7.0.1 (2015)
From http://tldp.org/LDP/abs/html/exit-status.html:
| A successful command returns a 0, while an unsuccessful one returns a
| non-zero value that usually can be interpreted as an error code.
So shouldn't the return value be 0 in this case, as the command did what
it was told?
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Rainer,
I cannot seem to replicate your issue:
G srorg6630/tmp ~> g.version
GRASS 7.1.svn (2015)
G srorg6630/tmp ~> g.list region
tmp
tmp.d.rast.edit.6753
tmp1
G srorg6630/tmp ~> g.copy region=tmp,tmp1 --overwrite
Copy region definition tmp@tmp to current mapset as
G srorg6630/tmp ~> echo $?
0
g.copy returns 1 when it cannot either read the source or write to the target. Please check your permissions on your region files in LOCATION/MAPSET/windows/.
Huidae
| 1
| GRASS 7.0.1 (2015)
So shouldn’t the return value be 0 in this case, as the command did what
it was told?
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
grass-dev mailing list
grass-dev@lists.osgeo.org
Huidae Cho <grass4u@gmail.com> writes:
Rainer,
tmp
tmp1
Copy region definition <tmp@tmp> to current mapset as <tmp1>
0
You are correct - they are read only.
So the return value is correct - but an error should be raised - or is
there a reason why this should silently fail?
Rainer
Huidae
| 1
| GRASS 7.0.1 (2015)
it was told?
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Rainer,
tmp
tmp1
0
It should probably not silently fail.
The code in question is in
lib/manage/do_copy.c
and potentially there to be added strerror(errno) as for example in
lib/gis/mapset_msc.c
Markus Neteler <neteler@osgeo.org> writes:
Rainer,
tmp
tmp1
0
Absolutely not - this can lead to errors as one assumes that no error
message means that the command was successful - I usually don't check
the return codes when I am working in a terminal.
I don't know the inner workings of GRASS - but it looks like a good place?
On a related note - are the return codes documented somewhere (apart
From the source code)? OK - 0 is evident, but the others? They seem to
have specific meanings in GRASS?
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
M_do_copy() returns a status. g.copy's main() checks that and uses it
to set the exit status, but it doesn't generate an error or warning if
the status is non-zero.
If G_recursive_copy() or M_do_copy() raised an error, that would
result in the program aborting on the first error; at present, it
copies as much as it can.
Realistically, g.copy() should be generating the error at the bottom
of main() if result is non-zero. E.g.
- exit(result);
+ if (result)
+ G_fatal_error(...);
+ return 0;
That would require G_recursive_copy() to call G_warning() (with the
appropriate strerror(errno)) for each failed system call. Either that,
or G_recursive_copy() would have to generate a "log" of failures so
that the caller can report them.
r66775 adds a warning for non-vector elements as well.
On Mon, Nov 9, 2015 at 6:20 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
M_do_copy() returns a status. g.copy’s main() checks that and uses it
to set the exit status, but it doesn’t generate an error or warning if
- if (result)
- G_fatal_error(…);
- return 0;
or G_recursive_copy() would have to generate a “log” of failures so
