[GRASS-DEV] RGBA_Color struct revisited
I've changed the new RGBA_Color struct in gis.h to remove the "set"
flag, and in its place added some RGBA_COLOR_* defines. These defines
can be inserted to preset the alpha channel so it can be used as an
on/off switch by things that don't otherwise handle alpha support.
So now we have:
typedef struct
    unsigned char r, g, b, a; /* red, green, blue, and alpha */
} RGBA_Color ;
typedef RGBA_Color RGB_Color;
/* RGBA_Color alpha presets */
#define RGBA_COLOR_OPAQUE 255
#define RGBA_COLOR_TRANSPARENT 0
#define RGBA_COLOR_NONE 0
see d.graph + D_symbol() for an example.
the RGB_Color struct can be used if you aren't interested in alpha or
having a color="none" option.
I hope all are happy with this and it will be useful for future coding.
Hamish
