[GRASS-dev] rotated ps.map
Hello,
I recently noticed a small bug(?) is ps.map. If the "-r" option is used
to rotate the plot, the output scale is automatically adjusted based on
an un-rotated map. In other words a map scaled to nicely fit on a
rotated page is scaled down based on the dimensions of the page which is
not rotated.
The attached patch for r_paper.c should fix this problem. Please test
and see if this is the best solution (maybe there is an easier fix) to
the problem.
Thanks.
Bob
(attachments)
r_paper.patch (2.07 KB)
On Wed, Aug 02, 2006 at 02:21:42PM -0300, Bob Covill wrote:
Hello,
not rotated.
the problem.
Thanks.
Bob,
I have applied your patch (untested) to CVS-HEAD.
Markus,
Thanks for applying the patch.
Bob
> Hello,
> not rotated.
> the problem.
> Thanks.
Bob,
