I need to rotate vector map at display time. I don't want to create a
new vector map ratated (like v.trasform) but I need a new option on
d.vect command like zrot in v.trasform.
This functionality is already developed or I must devolop it myself?
someone can suggest me the right mode to do that (I think to "copy"
part of v.trasform in d.vect)?
Thanks at all
Massimo Costantini
The latter.
Well, the easiest solution is a script which calls v.transform and
d.vect.
