[GRASS-dev] Run time errors on windows - grass 7.4
Hi All,
I am trying to compile Grass 7.4 stable version on Windows and followed the steps listed in the following link.
https://trac.osgeo.org/grass/wiki/CompileOnWindows
After successful compilation of Grass 7.4, I ran the grass executable from “C:\OSGeo4W64\bin” directory. However, it failed with the following error.
‘“C:\OSGEO4~1\bin\python.exe”’ is not recognized as an internal or external command,
operable program or batch file.
Python executable is not present in the directory “C:\OSGeo4W64\bin” directory.
Please let me know the any missing steps to fix this issue.
Thanks in advance for your help.
  • CM
Maybe this thread is related: http://osgeo-org.1560.x6.nabble.com/OSGeo4W-winGRASS-using-bash-in-console-scripts-not-working-td5382999.html#a5386454 ?
El jue., 22 nov. 2018 a las 19:45, CM Reddy (<chalamcharla@hotmail.com>) escribió:
Hi All,
  • CM
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Python executable is not present in the directory >"C:\OSGeo4W64\bin"
directory.
have you activated Python in osgeo4w?
how did you start the grass executable from "C:\OSGeo4W64\bin" directory.?
activate the grass package in osgeo4w and see if the package start.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
