[GRASS-dev] running v.surf.rst from GUI
On Mar 7, 2009, at 11:05 PM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Sun, 8 Mar 2009 07:05:07 +0100
Subject: Re: [GRASS-dev] running v.surf.rst from GUI
To: Helena Mitasova <hmitaso@unity.ncsu.edu>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID:
  <86782b610903072205u57a3b2c1sfe1c8cf4ff6f319b@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Helena,
On Sun, Mar 8, 2009 at 3:37 AM, Helena Mitasova <hmitaso@unity.ncsu.edu> wrote:
Markus,
thanks for getting back to me on this,
v.surf.rst runs fine from the tcltk gui, it but has several problems in
wxpython gui
(this is for today's update of grass65):
1. It is really hard to find where to put the name of the main output
"elevation"
- it is not under tab "outputs" but it is under tab "optional" which has
several inputs
that you actually must define if you don't want to end up interpolating
category
numbers. The tab optional isn't visible, so you need to click on the arrow
to get to it.
I think the elevation should be under outputs
I agree with you that it is hard to find (see screenshot attached).
The reason is that in
vector/v.surf.rst/main.c
the entry
parm.elev->guisection = _("Output_options");
is not defined. But see for related WX bug below...
Additionally:
In the Tcl GUI you get the parameter name shown, too. Would it be
possible to add that to the WX GUI, too? see attached screenshot
for what I mean.
Another suggestion: make the WX tabs consume less horizontal space
to see one more tab in the default width.
2. I was unable to change the layer number - it was stuck at 1
I just see that the description says:
   parm.field->description =
       _("Field value. If set to 0, z coordinates are used. (3D vector only)");
will take out "Field" as it is called "layer".
(this may be problem with my installation or I am not clicking on it the
right way?, typing it in, deleting it did not work either), so there was no way
to interpolate the z-coordinate.
I also don't see it. Seems to disappear somewhere. in the
Tcl GUI it's present.
I think that there is a bug for all parameters not having
guisection defined. They should go into the "Optional" tab
but they don't (they disappear apparently).
I think that the layer number should be under
input tab (required) - it is in fact required or you will end up
interpolating cats.
Then we have to make it required in main.c
The wx GUI is generated from what's defined there.
I would put column name there too, it is required for default layer 1,
otherwise cats
are interpolated. I do not find these defaults convenient but this was the
consensus by others when s.surf.rst was updated to v.surf.rst.
Again, it depends on parm->guisection...
Otherwise the new GUI is really, really nice - I hope we will be able to
switch to it for the fall 2009 classes.
Helena
P.S. Any chance for changing default layer to 0 at least in grass7,
to make it possible to run just v.surf.rst mypoints elev=myelev ?
Why not - in 7 we are allowed to change the defaults.
Just submit the change (please also check the html docs for update).
Without defining layer, it is set to 1 and category number is interpolated
by default if column is not defined - particularly unpleasant surprise
after running a longer computation. Layer number and column name can then be
under optional. I can make the change in grass7 if there are no objections
to see whether it will cause any problems.
I don't see problems.
A further followup. As Markus suggests, the wxpython GUI, like the TclTk one, depends on the options in main.c to know where to place controls and what to make them.
One issue that has already come up in another module (v.surf.bspline) is using layer=0 to select the z values for interpolation. This is a shortcut that is not really correct. Vector layers must be in the range of 1-n. There is no layer 0. This is a problem for the autogenerated GUI dialogs. All layer arguments must be treated the same way. In most cases, layer=0 is meaningless and generates an error. However, in a few modules, layer=0 is a shortcut for using the z value for interpolation. We cannot have it both ways in an autogenerated GUI.
My suggestion is to add a -z flag to indicate that the z-coordinates will be used. This would override any other data used for z-coordinate. Then layer arguments could remain at 1-n for all modules.
Michael
Hello Michael and others,
IMHO -z is the right way to go. It would be nice to open ticket for
such change and list affected modules to remember this idea.
My proposal: add -z == layer=0 to 6.x and replace layer=0 with -z in 7.x
Maris.
2009/3/8, Michael Barton <michael.barton@asu.edu>:
autogenerated GUI.
Michael
grass-dev mailing list
I agree with you Maris. How to open ticket? Where would this go?
Michael
Maris.
autogenerated GUI.
Michael
grass-dev Info Page
