me:
I have an idea for a s.cellstats replacement. Will call it r.in.xyz
[...] Output map options will be the same as r.univar.
David:
FYI. GMT implements several important filters for XYZ data that GRASS
lacks, for example binning data into a raster (be various means) grid
prior to actually importing the data. In some cases these can
substantially decrease the processing time of griding operations as
well as remove aliasing problems associated with some data set/griding
algorithm combinations.
Which is essentially s.in.ascii + s.cellstats + s.to.rast in GRASS 5.
So existing work arounds include "use GRASS 5", use GMT xyz2grd software
mentioned above & import GMT NetCDF to GRASS with r.in.gdal, and GRASS
s.to.rast2 add-on/LDART tool as mentioned by Helena. I guess there is a
solution using R-stats as well?
David:
A module like you suggest might benefit from some of these prefilters.
See the manual pages for GMT for FILTERING OF 1-D AND 2-D DATA at the
top of the GMT man pages:
http://gmt.soest.hawaii.edu/gmt/gmt_man.html
I'll have a look, thanks.
Helena:
s.cellstats inputs and outputs a site file,
technically, yes; but as s.cellstats output is gridded data preformed
for s.to.rast input, the s.to.rast step was implied.
what you are proposing is supposed to read an ascii x,y,z and output a
raster file?
yes. s.in.ascii + s.cellstats + s.to.rast in one step.
If that is true, you may want to look also at s.to.rast2 in GRASS
Add-ons: http://grass.itc.it/outgoing/
will do.
(it includes an option to include data from surrounding cells, so if
there are small holes in data, they can be filled-in).
For r.in.xyz, I think this is best left to r.neighbors & r.fillnulls.
Will you lose data resolution that way? I have not done the algebra to
check, but guess for the simple stats you will not. I guess you could
weight result due to uneven "n" in surrounding cells for average calc.
I have used s.to.rast a lot with lidar data or the binning option
that provides the on-line LDART tool (http://ekman.csc.noaa.gov/TCM/)
and I miss it a lot in GRASS6.
A more s.cellstats-like alternative could be a v.in.xyz.grid module,
which culls vector points to a grid ready for v.to.rast. Advantage is
access to advanced stats that s.cellstats has but r.univar does not, and
each point could have full stats as 7-10 attribute columns. This could
even be a -v flag from r.in.xyz. I'd rather the solution be that
r.univar get advanced stats support (median,..) from new library fns &
we could reuse the method in r.in.xyz. Note v.in.ascii memory limit is
much smaller than r.in.xyz (single-pass) memory limit. (~ 1750^2 grid vs
~ 10000^2 grid)
Your suggestion to go directly from ascii points to raster would get
around the problems that the current vector support has with large
data sets
That is the motivation & idea.
(otherwise I would have suggested to do v.in.ascii and add this to
v.to.rast so that attributes can be used instead of z as well).
I don't dispute the general need, but in practice the only massive point
dataset I can think of with more than x,y,z is sonar signal strength.
If there was a need the r.in.xyz module could have xcolumn= ycolumn=
zcolumn= parameters so 4th+ column could be used as z to make the
raster. Non-numeric + non-categorical attributes for that many input
points will have to be left for the future.
Hamish
