currently vector dbln file doesn't contain information about schema
(e.g. pg driver). This should be changed at least in GRASS7.
map[@mapset] layer table [key [database [driver]]]
I can see two possibilities:
1)
map[@mapset] layer [schema.]table [key [database [driver]]]
2)
map[@mapset] layer [schema.]table [key [database [schema] [driver]]]
I would vote for 2).
Any comments/ideas?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
2009/7/4 Martin Landa <landa.martin@gmail.com>:
This approach brings problems since for some DB backends (e.g. dbf) is
not schema defined, so
map[@mapset] layer [schema.]table [key [database [driver] [schema]]]
Martin
ops, it should have been
map[@mapset] layer table [key [database [driver] [schema]]]
Martin
