[GRASS-dev] Script for converting degrees clockwise from North to GRASS convention
I figured out that sometimes it would be useful to have a script for converting a direction map which uses the convention degrees clockwise from North, into the GRASS convention, which is as you well know degrees from East counterclockwise [1]. The aim is to deal with wind direction maps for example, which often use the above mentioned convention [2], but also some other software.
I wrote a short tentative of such conversion tool in the form of a grass addon for myself, enclosed. I would like to know:
  1. if would be of interest for anyone here, i.e. worth to be published in the addon repo;
  2. if you have any idea how to make the several time nested r.mapcalc expression less awful :slight_smile:
If we call WIND the direction map which uses the convention degrees clockwise from North, and GRASS the output map, the rule that I applied is:
IF 0 <= WIND < 270 ; GRASS = 270 - WIND
IF WIND = 270 ; GRASS = 360
IF 270 < WIND < 360 ; GRASS 630 - 0
IF WIND = null ; GRASS = 0
NULL otherwise (this latter I have added to check if there is any error.
If you are willing to countercheck my assumptions I’d appreciate.
cheers,
madi
[1] http://grass.osgeo.org/grass64/manuals/r.slope.aspect.html
[2] http://www.firewords.net/definitions/Wind_direction.htm
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
(attachments)
r.convert.aspect.py (1.76 KB)
On 22/01/13 17:45, Margherita Di Leo wrote:
1) if would be of interest for anyone here, i.e. worth to be published
in the addon repo;
+1, once it is correct.
2) if you have any idea how to make the several time nested r.mapcalc
For me it looks ok as is (with below corrections). Or maybe you could simply use r.recode with rules such as:
0:89.999:90:0.999
90:360:360:90
(probably need a better way to treat the special role of '0' in GRASS).
Give it a try.
This is not correct.
WIND = 0 means North. North in GRASS convention is 90, but 270 - 0 <> 90.
Same with WIND = 270 which is West IIUC, so this should be 180 in GRASS convention, not 360.
This should work I think:
IF 0 <= WIND < 90 ; GRASS = 90-WIND
IF 90 <= WIND <= 360 ; GRASS = 450 - WIND
Moritz
Hi Moritz,
thank you for your reply,
On Wed, Jan 23, 2013 at 12:21 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Actually this was tricky also for me, but:
Wind direction is measured in:
  • degrees clockwise from uphill (direction the wind is pushing the fire)
  • degrees clockwise from North (direction the wind is blowing from)
If the wind is blowing FROM north, it means that the arrow is TOWARDS south… Am I wrong?
Margherita DI LEO
Via Fermi, 2749
On 23/01/13 13:59, Margherita Di Leo wrote:
Hi Moritz,
        applied is:
        any error.
south.. Am I wrong?
I guess not, but this is a very specific application of angle direction. I think that if you want to create a generic module (r.convert.aspect or r.convert.angle) for transforming angles, then North should mean North. If for a specific application North means a direction a force is coming from, then the use should take that into account. In your case the original map gives the angle the wind is coming _from_, then the output should (IMHO) do the same.
Moritz
Moritz,
I really thank you for taking the time to discuss this.
On Wed, Jan 23, 2013 at 2:54 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Moritz,
<mlennert@club.worldonline.be mailto:[mlennert@club.worldonline.be](mailto:mlennert@club.worldonline.be)> wrote:
applied is:
any error.
south… Am I wrong?
I guess not, but this is a very specific application of angle direction. I think that if you want to create a generic module (r.convert.aspect or r.convert.angle) for transforming angles, then North should mean North. If for a specific application North means a direction a force is coming from, then the use should take that into account. In your case the original map gives the angle the wind is coming from, then the output should (IMHO) do the same.
This would be of no use for me (or the user) if it doesn’t match to the GRASS convention. So what I suppose I should do is to explain in the documentation that the input should be measured from SOUTH (0=SOUTH) clockwise.
Thanks!
Madi
Moritz
Margherita DI LEO
Via Fermi, 2749
        pushing the fire)
        blowing from)
        TOWARDS
        south.. Am I wrong?
This would be of no use for me (or the user) if it doesn't match to the
clockwise.
It all depends on whether you want to create a generic module that transforms angles between different conventions, or whether you want a very specific module for wind directions (although it is interesting to see that in you example the original data indicates the angle of origin of the wind, not of direction of the wind).
In the interest of other users, it might be better to create a generic angle transformation tool, which just transforms the angle of origin to its equivalent in the other convention without trying to interpret the meaning of that angle. However, it could be an option to include a flag that "reverses" the angles (i.e. transform a North angle into a South angle) in order to go from (in your wind example) origin to destination.
In terms of implementation, the easiest would probably be to chose one internal convention for the module and then code transformation from any other convention to and from that internal convention. Then you could just code once the "reversal" of angles in that convention.
Again, you could probably simply use r.recode: 0:360:360:0.
Just my 2¢ since you asked, but I understand that it might be overkill for your particular problem.
Moritz
On Wed, Jan 23, 2013 at 4:55 PM, Moritz Lennert
See also Glynn's answer in a previous post [0]
Markus M
[0] http://lists.osgeo.org/pipermail/grass-user/2009-January/048460.html
