[GRASS-dev] script output for g.list
Awhile ago, I think g.mlist output was changed so that it sent out a single list of maps or other GIS elements rather than a multicolumn list. Is there a way to add a flag to g.list so that it can produce output in the same way?
As it is, the output of g.list cannot easily be parsed within a script because of it’s multicolumn output. If the output could be a nice, clean single list, it would be parsable. Within a script, g.list is preferable over g.mlist for finding all relevant files in a mapset because it seems considerably faster.
Michael
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Hi Michael,
I tried to modify g.list. Instead of G_list_element(), the patch call
G_list() and G_ls_format() .
Patch attached (not committed to CVS).
E.g.
$ g.list rast
raster files available in mapset <martin>:
asp
raster files available in mapset <PERMANENT>:
aspect elevation.dem fields landuse roads
         soil.br.depth soils.ph strm.dist trn.sites
bugsites elevation.dted geology owner
rstrct.areas soils soils.range texture uparea
density erode.index landcover.30m quads
rushmore soils.Kfactor spot.image tractids
vegcover
elevation.10m erosion1 landcover.orig railroads slope
         soils.Tfactor streams transport.misc
$ g.list rast --q
asp
aspect
bugsites
density
elevation.10m
elevation.dem
elevation.dted
erode.index
erosion1
fields
geology
landcover.30m
landcover.orig
landuse
owner
quads
railroads
roads
rstrct.areas
rushmore
slope
soil.br.depth
soils
soils.Kfactor
soils.Tfactor
soils.ph
soils.range
spot.image
streams
strm.dist
texture
tractids
transport.misc
trn.sites
uparea
vegcover
Martin
2007/9/3, Michael Barton <michael.barton@asu.edu>:
because of it's multicolumn output. If the output could be a nice, clean
single list, it *would* be parsable. Within a script, g.list is preferable
Michael
phone: 480-965-6213
fax: 480-965-7671
grass-dev mailing list
grass-dev@grass.itc.it
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
(attachments)
g-list-vq.diff.gz (1.93 KB)
Martin Landa wrote on 09/04/2007 11:37 AM:
Hi Michael,
$ g.list rast --q
asp
aspect
bugsites
density
Hi Martin,
wouldn't it be more sensitive to use '-g' instead?
Also in combination with -f for the titles?
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
Thanks very much Martin. Not knowing C, I'm not exactly sure what to do with
this, but will try to work with it if no one else gets to it first. I'm not
sure I'd hang the different format on the --q flag. Maybe a -l (for
listing?) flag would be better.
Once this is worked out and in the cvs, I'll put it into select.py. I don't
know if you've had a chance to look, but I added a class to allow select to
be called in a separate dialog and a method that lets you update the element
list after you've created a selection control.
Michael
On 9/4/07 2:37 AM, "Martin Landa" <landa.martin@gmail.com> wrote:
Hi Michael,
E.g.
$ g.list rast
asp
vegcover
$ g.list rast --q
asp
aspect
bugsites
density
elevation.10m
elevation.dem
elevation.dted
erode.index
erosion1
fields
geology
landcover.30m
landcover.orig
landuse
owner
quads
railroads
roads
rstrct.areas
rushmore
slope
soil.br.depth
soils
soils.Kfactor
soils.Tfactor
soils.ph
soils.range
spot.image
streams
strm.dist
texture
tractids
transport.misc
trn.sites
uparea
vegcover
Martin
Michael
phone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
Hi Michael, Markus, ...,
that's true, '--q/--v' should not influence format for listing in this
way! I added parameter 'ncols' for "Number of elements per line". But
the verbose listing still uses G_list_elements(), so 'ncols' doesn't
work together with '-f' flag.
Path attached.
For scripting
$ g.list rast ncols=1 --q
$ g.list help
Description:
Lists available GRASS data base files of the user-specified data type
to standard output.
Keywords:
general, map management
Usage:
g.list [-f] type=datatype[,datatype,...] [mapset=string] [ncols=value]
   [--verbose] [--quiet]
Flags:
  -f Verbose listing (also list map titles)
        Prints one element per line
--v Verbose module output
--q Quiet module output
Parameters:
    type Data type
           options: rast,rast3d,vect,oldvect,asciivect,icon,labels,sites,
                    region,region3d,group,3dview
  mapset Mapset to list (default: current search path)
   ncols Number of elements per line (0 for autodetect)
           default: 0
Martin
2007/9/4, Michael Barton <michael.barton@asu.edu>:
Michael
> Hi Michael,
> E.g.
> $ g.list rast
> asp
> vegcover
> $ g.list rast --q
> asp
> aspect
> bugsites
> density
> elevation.10m
> elevation.dem
> elevation.dted
> erode.index
> erosion1
> fields
> geology
> landcover.30m
> landcover.orig
> landuse
> owner
> quads
> railroads
> roads
> rstrct.areas
> rushmore
> slope
> soil.br.depth
> soils
> soils.Kfactor
> soils.Tfactor
> soils.ph
> soils.range
> spot.image
> streams
> strm.dist
> texture
> tractids
> transport.misc
> trn.sites
> uparea
> vegcover
> Martin
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>> _______________________________________________
phone: 480-965-6213
fax: 480-965-7671
(attachments)
g-list-vq-2.diff.gz (2.46 KB)
