Hello Mr. Clements
But, for instance, I have just made a NDVI script (i.ndvi) and I added the file to my script folder but I got the following error:
File “/usr/local/grass-6.4.0svn/etc/wxpython/wxgui.py”,
line 466, in OnRunCmd
self.goutput.RunCmd(cmd, switchPage=False)
File “/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/g
output.py”, line 352, in RunCmd
menuform.GUI().ParseCommand(cmdlist, parentframe=self)
File “/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/m
enuform.py”, line 1822, in ParseCommand
handler)
File “/usr/lib/python2.6/xml/sax/init.py”, line 49, in
parseString
parser.parse(inpsrc)
File “/usr/lib/python2.6/xml/sax/expatreader.py”, line
107, in parse
xmlreader.IncrementalParser.parse(self, source)
File “/usr/lib/python2.6/xml/sax/xmlreader.py”, line 123,
in parse
self.feed(buffer)
211, in feed
self._err_handler.fatalError(exc)
File “/usr/lib/python2.6/xml/sax/handler.py”, line 38, in
fatalError
raise exception
xml.sax._exceptions
SAXParseException
:5:3: not well-formed (invalid token)
Could you tell me what’s wrong? Am I suppose to do something else?
Best regards,
Kim
2010/1/25 Glynn Clements <glynn@gclements.plus.com>
Kim Besson wrote:
I’m having a few Questions regarding Scripting developing and compilation
for LINUX. I have “coded” a Script example, from GRASS book, and now I just
want to try it. But it says “Command d.rast.region is not yet implemented”.
Do I have to do something because it’s already in the right
folder /usr/local/grass-6.4.0svn/scripts.
The “not yet implemented” error occurs if you run unknown d.* commands
(any command beginning with “d.”) from the GUI’s interactive prompt.
Essentially, support for running d.* within the GUI is an ugly hack;
it “traps” a fixed set of known commands, but doesn’t work for
anything else.
You should still be able to use the script from the shell, or by
adding a command layer within the GUI.
