So far, I've only seen this in Vista and am wondering if anyone else has seen it. Using the nightly build from 2 February.
From the command line, type the name of a script, like r.blend, without arguments
Instead of the GUI popping up, there is an error complaining about the lack of arguments.
It's like g.parser is not being invoked.
### second issue
Also, copy a script and rename the copy (e.g., copy r.blend to r.blend2), leaving it in the scripts folder, then copy the script's *.bat file (in bin), rename the copy (e.g., , e.g., r.blend.bat to r.bend2.bat), and edit the *.bat file so that it points to the proper renamed script copy (e.g., now points to r.blend2). Type the script's name on the msys command line and press return.
There is an error that the script cannot be found.
Any thoughts?
I'm trying to help some students learn scripting. It is frustrating that even correctly written scripts don't work.
without arguments
lack of arguments.
What error, exactly?
### second issue
February.
it's funny that we all noticed this at the same time, but actually it
is all modules and it's been like that for a long time (if not always).
I had tried a WinGrass installer from December (well before the latest
rounds of argv[0] and G_spawn() changes) and it was the same. --ui is
needed from the msys prompt.
I tried from the DOS prompt as well (even setting GRASS_GUI=wxpython),
but that just returns you to the C:\> prompt. You can start g.gui from
there ok though. shrug.
### second issue
Any thoughts?
.. perhaps restart GRASS? ?
February.
Odd. I guess it's that we don't use Windows regularly enough to spot this kind of thing. It underscores the need for more
Windows testers.
### second issue
Any thoughts?
I'll suggest it.
understood.
If we can get the Python thing worked out I keep hoping that this will all improve a lot.
It works for me with GRASS_GUI=wxpython (for recent versions of 6.4; I
think that you'll need r40717 if there are spaces in $GISBASE).
> ### second issue
> Any thoughts?
