Von: "Glynn Clements"
Gesendet: 04.02.10 21:16:59
Helmut Kudrnovsky wrote:>So far, I've only seen this in Vista and am wondering if anyone else has seen it. Using the nightly build from 2 February.
>From the command line, type the name of a script, like r.blend, without arguments
>Instead of the GUI popping up, there is an error complaining about the lack of arguments.
>It's like g.parser is not being invoked.i can confirm this changed behaviour, typing a command without arguments and no GUI popping up.
tested on WinVista32 with self compiled Grass64 and Grass65
Note that if GRASS_GUI is tcltk, it won't work, due to G_popen() not
working at all on Windows (execl() works like on Unix, i.e. it doesn't
return if it succeeds; but unlike Unix, Windows doesn't have fork()).Using the new G_popen() from 7.0 is one option.
I've tried this from the msys-shell, for example g.region, r.blend, ..., and if I remember correctly, this worked by popping up the gui until a week ago or so.
here is the error message:
"GRASS 6.4> r.blend
Fehler: Benötigter Parameter <first> ist nicht gesetzt:
(Name der ersten Rasterkarte für die Mischung.).
error: needed parameter <first> not set
Fehler: Benötigter Parameter <second> ist nicht gesetzt:
(Name der zweiten Rasterkarte für die Mischung.).
error: needed parameter <second> not set
Fehler: Benötigter Parameter <output> ist nicht gesetzt:
(Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung.).
error: needed parameter <output> not set"
but it's working from the wx-gui-command-line, from the tcltk-command-line (by the buttons "run in background","run GUI", and "run in DOS-box").
tested here on another WinVista32-box withthe nightly build WinGRASS-6.4.SVN-r40792-1-Setup.exe
Helmut
______________________________________________________
GRATIS für alle WEB.DE-Nutzer: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://movieflat.web.de
