Hi devs,
I would like to have seasonal granularity into Temporal Framework, is
this possible?
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Hi devs,
this possible?
ciao
Luca
www.lucadelu.org
Hi Luca,
what kind of seasons do you think of?
Meteorological seasons?
They have a granularity of 3 months, so this should be possible already.
If you need the astronomical seasons this is unfortunately not
possible, since a user defined granularity is not supported.
Why do you need a seasonal granularity?
Best regards
Soeren
2015-08-13 14:35 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi devs,
this possible?--
ciao
Lucahttp://gis.cri.fmach.it/delucchi/
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Soeren,
On Thu, Aug 13, 2015 at 5:55 PM, Sören Gebbert
<soerengebbert@googlemail.com> wrote:
Hi Luca,
For example, we would need something like this (Northern hemisphere):
- spring: 22/03/ .. 20/06/
- summer: 21/06/ .. 23/09/
- autumn: 24/09/ .. 20/12/
- winter: 21/12/ .. 21/03/
It would be *really* good to let the user decide the start/end date of
the seasons.
thanks
Dear Markus and Luca,
feel free to implement user defined granularities in t.register. It
should be convenient to use something like "astro_seasons" as
identifier to apply the astronomical seasons to map layers that should
be registered in the temporal database.
However, the computed granularity of the resulting space-time dataset
will be 1 day, unless you modify the granularity computation in
lib/python/temporal/temporal_granularity.py to acknowledge user
defined granularities. Which would be really nice indeed.
Best regards
Soeren
2015-08-13 22:08 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Hi Soeren,
<soerengebbert@googlemail.com> wrote:Hi Luca,
what kind of seasons do you think of?For example, we would need something like this (Northern hemisphere):
- winter: 21/12/ .. 21/03/It would be *really* good to let the user decide the start/end date of
the seasons.thanks
to reduce a bit of confusion. You can apply a time interval of
arbitrary size to a map layer. Use the input file option of t.register
and specify the interval size in the input file:
name|start_time|end_time
map_1|2001-03-22 00:00:00|2001-06-21 00:00:00
map_2|2001-06-21 00:00:00|2001-09-24 00:00:00
map_3|2001-09-24 00:00:00|2001-12-21 00:00:00
map_4|2001-12-21 00:00:00|2002-03-22 00:00:00
Be aware that time intervals in the temporal framework are left
closed, right open intervals. Hence, the end time is not part of the
interval, but the start time of a potential successor.
This assures gap free creation of temporal topological correct time series.
The computed granularity of the resulting space-time dataset (STDS)
will be 1 day, since 1 day is the greatest common divider of all the
seasonal time intervals in the STDS.
IMHO, there is no urgent need to support a user defined granularity in
the temporal framework. The Gregorian Calendar hierarchy is almost
sufficient.
Best regards
Soeren
2015-08-13 23:35 GMT+02:00 Sören Gebbert <soerengebbert@googlemail.com>:
defined granularities. Which would be really nice indeed.Best regards
Soeren2015-08-13 22:08 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Hi Soeren,
the seasons.thanks
On 13 August 2015 at 23:35, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Dear Soeren,
sorry for delay
more than in t.register I would like to have "astro_seasons"
granularity for aggregation,
yes this is a useful starting point, but probably something else
should be modify, could you give me other hints?
Best regards
Soeren
ciao
Luca
www.lucadelu.org
On 14 August 2015 at 00:35, Sören Gebbert <soerengebbert@googlemail.com> wrote:
yes in t.register there aren't problems...
...Be aware that time intervals in the temporal framework are left
This assures gap free creation of temporal topological correct time series.The computed granularity of the resulting space-time dataset (STDS)
sufficient.
for the aggregation I think this is needed...
how can I calculate average seasonal temperature starting from a daily
temperatures temporal dataset?
Best regards
Soeren
ciao
Luca
www.lucadelu.org
Hi Luca,
Am 19.08.2015 12:01 schrieb “Luca Delucchi” <lucadeluge@gmail.com>:
and specify the interval size in the input file:yes in t.register there aren’t problems…
…Be aware that time intervals in the temporal framework are left
sufficient.for the aggregation I think this is needed…
Use t.rast.aggregate.ds, the input is the daily strds, the sampling stds should have seasonal intervals. Then use average as method. The output will have seasonal aggregated temperatures.
Best regards
Soeren
Best regards
Soeren–
ciao
Luca
Ciao Luca,
Just following the example in t.rast.aggregate.ds manual page, I added a section for seasonal aggregation [0] to the “Temporal data processing” wiki, showing how to get astro_seasonal aggregation from a daily time series. I guess you already solved the problem, but at least it is there for future reference
It would be awesome, anyway, to have astro_season as a predefined granularity!! Way more simple!!!
Vero
[0] https://grasswiki.osgeo.org/wiki/Temporal_data_processing/seasonal_aggregation
2015-08-19 10:46 GMT-03:00 Sören Gebbert <soerengebbert@googlemail.com>:
Hi Luca,
temperatures temporal dataset?Use t.rast.aggregate.ds, the input is the daily strds, the sampling stds should have seasonal intervals. Then use average as method. The output will have seasonal aggregated temperatures.
Best regards
SoerenBest regards
Soeren–
ciao
Luca
