Colin wrote:
My map display for the location shows the correct UTM
coordinates (attachment 1), but when I display a raster file,
the coordinate system changes and the scale bar is wildly out
(attachment 2).
in attachment two the coordinates in the bottom-left are -80.43,
-0.38, not UTM like in attachment one.
what does 'r.info your_raster_name' say about the N,S,E,W bounds
of the raster image, and the image resolution?
is it an imported map or a self-created one?
guess: Maybe the imported map was lat/lon not UTM and it needs
to be imported to lat/lon then r.proj'd into the UTM location?
(or use gdalwarp as appropriate)
Hamish
