Quentin wrote:
>> i try to work grass with windows (wingrass). the version is
>> grass6.3.
If you can manage to install a 6.4.0rc, many things may be fixed.
>> I can see the picture but when I try to see the same
>> picture in v.digit I have the white screen. i can see vector
>> that i draw but not the pcture. i don't have error message.
Hamish:
> maybe it is a zooming off-page / computational region problem?
> try "g.region rast=picture1@my_mapset" first
i try this instruction but i have th e problem.
when i tryv.digit -n map=name_of_vector bgcmd="picture1@my_mapset"
i have the white screen and
(bgcmd needs to have the d.rast part too, not just a map name)
v.digit -n map=name_of_vector bgcmd="d.rast picture1@my_mapset"
i hace the error message
d.rast picture1@my_mapset is not a coorect instruction
are you running this from the GUI or from the command prompt?
In the tcltk gis.m GUI output window + [Run] box thing the command
needs to be quoted in Tcl style:
v.digit -n map=name_of_vector bgcmd={d.rast picture1@my_mapset}
hope it helps,
Hamish
