[GRASS-dev] seg fault with temporal modules
Hi devs,
I get ‘Segmentation fault (core dumped)’ after running temporal commands. Commands work, but they finish with segfault. I started observing this yesterday evening that I recompiled trunk to get lattest temporal changes. I was working with temporal modules the day before that with no issues.
Luca suggested off-list that my DB must be corrupted somehow because others do not have that issue and neither myself in a different machine with freshly compiled trunk. So, I’m lost…
To test further I did 2 things:
1). remove my nc_basic location and download it again in my grassdata:
GRASS 7.7.svn (nc_basic_spm_grass7):~ > t.connect -d
Default driver / database set to:
driver: sqlite
database: $GISDBASE/$LOCATION_NAME/$MAPSET/tgis/sqlite.db
GRASS 7.7.svn (nc_basic_spm_grass7):~ > t.list
WARNING: Temporal database connection defined as:
/home/veroandreo/grassdata/nc_basic_spm_grass7/PERMANENT/tgis/sqlite.db
But database file does not exist.
Creating temporal database:
2). create a new grassdata and download a different location
GRASS 7.7.svn (worldlocation):~ > t.connect -d
driver: sqlite
GRASS 7.7.svn (worldlocation):~ > t.list
/home/veroandreo/grassdata_test/worldlocation/PERMANENT/tgis/sqlite.db
same result… any other ideas??
Thanks much in advance!
Vero
On Fri, Sep 28, 2018 at 3:18 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Hi devs,
I get 'Segmentation fault (core dumped)' after running temporal commands. Commands work, but they finish with segfault.
We has a similar (?) problem here:
    On Sat, Jul 28, 2018 at 11:40 PM Veronica Andreo wrote...
The reason was a broken external library. Maybe that problem came back
in a system update?
You may try t.info with strace like the last time.
Best
in a system update?
Seems that
https://bugzilla.redhat.com/show_bug.cgi?id=1605231
may be back, i.e. bug reintroduced in openblas-0.3.3 (the update just
came in through the Fedora update channel)...
I'll check later on my system.
Best
Seems that
Reported upstream as
https://bugzilla.redhat.com/show_bug.cgi?id=1634060
Markus Neteler <neteler@osgeo.org> schrieb am Fr., 28. Sep. 2018, 17:46:
Seems that
came in through the Fedora update channel)…
Fixed upstream:
<bugzilla@redhat.com> schrieb am So., 30. Sep. 2018, 15:44:
— Comment #2 from Fedora Update System <updates@fedoraproject.org> —
openblas-0.3.3-2.fc28 has been submitted as an update to Fedora 28.
https://bodhi.fedoraproject.org/updates/FEDORA-2018-dcb9bcdb5c
It may take a day to propagate through the update channel.
Other distros will follow or still have an older openblas package version…
Hi Markus,
Thanks much for reporting the issue and then reporting back here. I had completely forgotten that we had the same issue shortly ago… eheh
Vero
Seems that
Fixed upstream:
On Sun, Sep 30, 2018 at 9:08 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Hi Markus,
Thanks much for reporting the issue and then reporting back here. I had completely forgotten that we had the same issue shortly ago... eheh
I just upgraded openblas-0.3.3-2 from the Fedora testing server, it is
functional again and t.list works as expected.
