[GRASS-dev] Segmentation Fault in addition to r.walk code
My first post to this list, so go easy.
I've been playing with the r.walk code for my own purposes. I've been
trying to add functionality for a second output file. Basically I
copied everything done to the original output file, but with different
file names. The odd thing is, that I get a seg fault on
    segment_put(&out_seg2, &fbuff[i], row, i); when above it worked
fine for the original &out_seg. The relevent bits of code are below
(though tell me if I should post the whole thing):
    void *dtm_cell, *cost_cell, *cum_cell, *dir_cell, *cell2 = NULL;
//cn: added dir_cell
    SEGMENT dtm_in_seg, cost_in_seg, out_seg, out_seg2; //cn: added
out_seg2 for move dir
    char *cum_cost_mapset, *move_dir_mapset; //cn: added move_dir_mapset
    char *dtm_in_file, *cost_in_file, *out_file, *dir_out_file; //cn:
added dir_out_file
    double *dtm_value, *cost_value, *value_start_pt, *dir_value; //cn:
and dir_value
    double cur_dir, old_cur_dir; //cn: added cur_dir and old_cur_dir
    int cost_fd, cum_fd, dtm_fd, dir_fd; //cn:added dir_fd
    int dtm_in_fd, cost_in_fd, out_fd, dir_out_fd; //cn: added dir_out_fd
    struct Option *opt9, *opt10, *opt11, *opt12, *opt13, *opt14,
*opt15; //cn: added *opt15
    /*CN: added the opt for outputing the raster of movement directions*/
    opt15 = G_define_option();
    opt15->key = "outdir";
    opt15->type = TYPE_STRING;
    opt15->required = YES;
    opt15->gisprompt = "new,cell,raster";
    opt15->description = _("Name of output raster map to contain
movement directions");
    strcpy(cum_cost_layer, opt1->answer);
    current_mapset = G_mapset();
    /* Search for output layer (cum_cost_layer) in all mapsets */
    search_mapset = "";
    cum_cost_mapset = G_find_cell2(cum_cost_layer, search_mapset);
    /*CN: Copy the specified filename to a new file*/
    strcpy(move_dir_layer, opt15->answer);
    /*CN: Search for output layer (move_dir_layer) in mapsets*/
    search_mapset = "";
    move_dir_mapset = G_find_cell2(move_dir_layer, search_mapset);
    if (G_legal_filename(cum_cost_layer) < 0)
  G_fatal_error(_("<%s> is an illegal file name"), cum_cost_layer);
  /*CN: check if layer name is legal*/
  if (G_legal_filename(move_dir_layer) < 0)
  G_fatal_error(_("<%s> is an illegal file name"), move_dir_layer);
    out_fd = creat(out_file, 0600);
    segment_format(out_fd, nrows, ncols, srows, scols, sizeof(double));
    close(out_fd);
    /*cn: create a seg file for dir output*/
    dir_out_fd = creat(dir_out_file, 0600);
    segment_format(dir_out_fd, nrows, ncols, srows, scols, sizeof(double));
    close(dir_out_fd);
    out_fd = open(out_file, 2);
    segment_init(&out_seg, out_fd, segments_in_memory);
    /*cn: and the dir output file*/
    dir_out_fd = open(dir_out_file, 2);
    segment_init(&out_seg2, dir_out_fd, segments_in_memory);
    /* Initialize output map with NULL VALUES */
    /* Initialize segmented output file */
  G_message(_("Initializing output "));
  double *fbuff;
  int i;
  fbuff = (double *)G_malloc((unsigned int)(ncols * sizeof(double)));
  if (fbuff == NULL)
      G_fatal_error(_("Unable to allocate memory for segment fbuff == NULL"));
  G_set_d_null_value(fbuff, ncols);
  for (row = 0; row < nrows; row++) {
    G_percent(row, nrows, 2);
      for (i = 0; i < ncols; i++) {
    segment_put(&out_seg, &fbuff[i], row, i);
  segment_flush(&out_seg);
  G_free(fbuff);
    /*cn:init segmented dir output file */
    G_message(_("Initializing directional output "));
  double *fbuff;
  G_message(_("*fbuff"));
  int i;
  G_message(_("fbuff"));
  if (fbuff == NULL)
  G_message(_("set_d_null"));
        G_message(_("almost seg_put <%d>"), &fbuff[i]);
    G_message(_("done seg_put"));
  G_message(_("almost seg_flush"));
  segment_flush(&out_seg2);
  G_message(_("done seg_flush"));
  G_free(fbuff);
  G_message(_("G_free"));
It compiles fine but when I run it, I get a segmentation fault at
segment_put(&out_seg2,....
Thanks, I hope someone can help.
-CN
