Pierre,
I think the main issue with doing *.las would be that although LAS data is coming in tiled but is also available as overlapping swaths. I imagine to impliment the option for multiple las files you would need to build an internal index of the “footprint” of each input las file that tells r.in.lidar and v.in.lidar which file(s) to draw the input las data from to create the output. In the case of r.in.lidar, you would need to specify which files to simultaneously open to gather the point values to calculate the statistics that are the value of the output cell. You would need something like the way gdaltindex builds a polygon shape file from a list of input georeferenced images. ( Now if I only had some skill with C to throw together some code )
In the short term, use the las2las command from liblas.org to merge your .las files into a single las file and then process the one file. You will have to watch out for the 4 billion point limit that is currently in the LAS file format, but for most folks that’s not an issue.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
To
Markus Metz <markus.metz.giswork@googlemail.com>
cc
grass-dev <grass-dev@lists.osgeo.org>
Subject
Re: [GRASS-dev] Segmentation fault using v.in.lidar
Thanks for the quick answer Markus,
That would be a nice feature to add though. A lot of the LAS files are
coming "tiled", and it'd be nice to be able to do something like:
v.in.lidar in=*.las out=test_input_lidar -trb
or
v.in.lidar in=zone_32_*.las out=test_input_lidar -trb
to import a special subset of LAS files.
I've very few coding abilities, so this is just meant as another line
on the wishlist ;)
Thanks heaps for your work on *.in.lidar, it is working well otherwise,
Pierre
2011/7/13 Markus Metz <markus.metz.giswork@googlemail.com>:
> On Wed, Jul 13, 2011 at 2:08 AM, Pierre Roudier
> <pierre.roudier@gmail.com> wrote:
>> Hi,
>> I've been trying to use v.in.lidar. It yields good results on one LAS
>> file, but I get a segfault when trying it on several files:
>>> v.in.lidar in=BD32_1610.las,BD32_1611.las out=test_input_lidar -trb
>> Segmentation fault
>>> v.in.lidar in=BD32_161*.las out=test_input_lidar -trb
>> Segmentation fault
>> Am I missing something, or is it a bug?
> v.in.lidar takes only one input file at a time.
> Markus M
Scientist
Landcare Research, New Zealand
grass-dev mailing list
